I've been doing some research on an "all in one" amp to do 5.1. Only three have made the cut....
1.
Audiobahn A5100T
Features
4-Ohm RMS Power Output
Front: 125W x 2
Center: 75W x 1
Rear: 75W x 2
Subwoofer: 300W x 1
2-Ohm RMS Power Output
Front: 200W x 2
Center: 130W x 1
Rear: 130W x 2
Subwoofer: 500W x 1
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Double Sided Glass Epoxy Circuit Board
6-Channel RCA Input
Variable 18dB High / Low-Pass Crossovers
Variable Subsonic Filter
3-Way Protection Circuitry
Cobalt Blue Illumination
Blue LED Voltage and Status LEDs
High Gloss Chrome-Plated Finish
Nickel-Plated Block Terminals
Fan Cooled with Flame Fan Grille
2.
Soundstream D'Artagnan
• RUBI™ (Rapid-Use Branched Impulse) Proprietary power supply topology
• STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
• Auto High Current™ Matches the amplifier for virtually every load application
• Chassisink™ Transistors are located between circuit board and heatsink for optimal heat dissipation
• Variable Input level controls for exact input match to amplifier
• Continuously variable 24dB low-pass crossover (40Hz to 220Hz)
• Continuously variable 12dB high-pass crossover (50Hz to 200Hz)
• Hawkins Bass Control™ Proprietary bass equalization topology
• Harmonic Bass Alignment™ Produces tighter and more accurate bass reproduction
• Continuously variable subsonic filter (13Hz to 30Hz)
• Trident™ amplifier protection topology
• IDI™ (Intelligent Distress Indicator) gives visual conformation of protection status
• Balanced Line inputs for the highest level of noise rejection • Platinum RCA input and output
• Platinum 4 gauge power inputs
• 10Hz – 30 kHz frequency response
• >100dB S/N ratio• 0.02% THD• 6 Channels
• RMS @ 4 ohm 65 x 5 + 200 x 1
• RMS @ 2 ohm 100 x 5 + 400 x 1
• RMS @ 1 ohm 500 x 1 (sub only)
• Dimensions: 19” x 11.5” x 2.25”
3.
Soundstream DaVinci
SPECS
NUMBER OF CHANNELS 7
OUTPUT POWER (WATTS): RMS @ 4 Ohms 50 x 4,+100 x 2,+200 x 1
RMS @ 2 Ohms 100 x 4,+200 x 2,+ 400 x 1
RMS @ 1 Ohms 500 x 1 (subwoofer channel only)
T.H.D.: <0.02%
FREQUENCY RESPONSE: Channels 1-6 15 - 50k
Channel 7 25 - 2k
SIGNAL TO NOISE RATIO: >100dB
CHANNEL SEPERATION: >60dB
DAMPING FACTOR: >200
INPUT SENSITIVITY: 500mV - 5.0V
CROSOVER SLOPES: High-pass/Band-Pass 12dB
Low-Pass 24dB
CROSSOVER FREQUENCIES (HZ):* High-pass/Band-Pass 50 - 4k
Low-Pass 200-800
REAR CHANNEL DE-EMPHASIS: 6dB
DIMENSIONS (INCHES): 19 x 14 x 5.5
IMHO, the Audiobahn A5100t has the best bang for your buck (better specs than the D'Artagnan), but the DaVinci is my dream setup.
