Old 04-28-2004, 01:41 PM   #1
Jesus Freak
antimatter's Avatar
4 to 6 channel amp recomendation for 5.1 DD
I am in the market for a good clean sounding 4 to 6 channel amplifier. The immediate needs are for a 4 channel amp for the Front LR and Rear LR speaker. but if it has a chanel for the subwoofer and center channel i will be willing to evaluate it.
I am looking for your advice on high quality / reletivly cheap car amplifiers. I want a brand with a good name and am looking to spend 100-450 (would like to hit somewhere in the middle)
antimatter is offline   Reply With Quote
Old 04-28-2004, 02:41 PM   #2
falconey's Avatar
First off if you find a 6 channel amp I guarantee it won't be cheap. I don' think I've ever even heard of a six channel amp. You may be able to find a 5 channel, but again I'm sure it won't be cheap. As far as your as a 4 channel goes you need to post more info. What speakers are you pushing and what type of power do they require or do you want going to them? On the suggestion side of things: You can go with a set up with more than one amp. In my current set up I only have a front stage with 2-5.25's and 2 tweets running off one amp and then I have my subs running off another. I think this is your best option and if you're just looking for good quality sound and aren't trying to win competitions, I suggest staying withing the power requirements of your speakers and just buying a name brand amp in your price range. Of course if you provide the power requirements then you could end up with more suggestions.
falconey is offline   Reply With Quote
Old 04-28-2004, 02:55 PM   #3
Six channel amp http://jlaudio.com/amps/e6450.html , can buy here http://www.procarstereo.com/product....d=2896&a=10001
Pioneer DEH7600MP, Autotek MX-800.4, JL Audio XR650-CSi, Adire Audio Shiva
Done with CarPCs, using a iPaq 3765 PDA w/ Holux GM210 and TomTom
blackaccrd00 is offline   Reply With Quote
Old 04-28-2004, 02:57 PM   #4
im sorry but i have to post this even though it will cost a fortune, and ive never seen them for sale!!
its a 6 channel 5x50W + 1x250W digital amp, i.e. it has an spdif in!
http://www.tbk.co.kr/eng/products_so...um=3&idorder=0
dominic is offline   Reply With Quote
Old 04-28-2004, 03:34 PM   #5
Jesus Freak
antimatter's Avatar
Okay sorry i didn't provide enough information...
The speakers in the front and back (FL FR BL BR) will need to handle 50-100w rms
http://www.crutchfield.com/S-K92Niu6...=1&cc=01&avf=Y
I think i will stick with a two amp configuration 1 amp for the 5 speakers up front (center chanel included preferably) and 1 mono amp for the Subwoofer.
I want atleast 500w RMS probably 1 12"
Any specific amp models?
Old 04-28-2004, 04:43 PM   #6
Squid's Avatar
Thumbs up My solution...
I just put a Kicker KX700.5 5-channel amp in my SUV.
http://www.kicker.com/ShowPage.cfm?f...ml&menu=KXAMPS
Has remote bass gain knob, built in cooling fan, also included aluminum endcaps to
conceal the wires.
I have it running (4) 6.5" component speakers and a Kicker L7 10" sub in a sealed
enclosure (all at 2 ohms). Still getting whole carputer setup, but I've tested the
system many times now and I'm more impressed by the sub/amp combo every time.
The MSRP for the amp is $499, but I got it for just under $300 on ebay.
As for the center channel, I'm using a small amp and (2) 3.5" speakers.
Squid is offline   Reply With Quote
Old 04-28-2004, 05:51 PM   #7
cadence117's Avatar
Okay how about for some cheaper priced 4 channel amps with 5.1?
mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
Total = $746....Carputer = Priceless
cadence117 is offline   Reply With Quote
Old 04-28-2004, 06:05 PM   #8
Soundstream D'artagnan can be had for about 400 off ebay.
5.1 sound, sub channel is 500 watts @1Ohm stable!
ZanGManN is offline   Reply With Quote
Old 04-28-2004, 07:00 PM   #9
Jesus Freak
antimatter's Avatar
Question
• RMS @ 4 ohm 65 x 5 + 200 x 1
• RMS @ 2 ohm 100 x 5 + 400 x 1
• RMS @ 1 ohm 500 x 1 (sub only)
Information says the above.
I got a questions...
What class is it A/B, D,
Also it appears that if my speakers are 2 ohms i can get 100wRMS on 5 channels and 400 watts RMS for the sub @ 2 ohms
Old 04-28-2004, 07:16 PM   #10
I dont think Soundstream has ever used class D power/amps, even my 2 channel 5.0 which runs clean down to .5 ohms is a class A amp. Can't be absolutely sure though, just my assumption. Couldn't find any documentation on the web.
Old 04-28-2004, 07:17 PM   #11
Jesus Freak
antimatter's Avatar
Thanks, Just curious cause i didn't see it listed and I am not aware of Soundstream
Old 04-28-2004, 07:22 PM   #12
Really good amps IMHO i have 2 MMATS pro series hooked up running at a 1Ohm load. The amp (Soundstream Reference Class A 5.0) has never had any problems, although it does tend to run a little hot. (I've had the amp for about 4 years now and it has blown several sets of subs, however these MMATS seem to keep up well)
Old 04-28-2004, 08:18 PM   #13
The classes are what type of amplification it is.
D is digital amplication which means 100% of the signle is amplified.
Class A amplifies 100% with no distortion
anc Class B amplifies 50% with distortion.
Raged is offline   Reply With Quote
Old 04-28-2004, 11:36 PM   #14
Jesus Freak
antimatter's Avatar
Thanks Raged,
The classes are important. Class D is good subs becasue the frequency that the noise is comonly found is usually filtered out by low pass crossover. Most A amps are really A/B combos.
I don't want a D. I want an A/B
I did order the soundtreem
Old 04-29-2004, 07:05 AM   #15
falconey's Avatar
Quote: Originally Posted by antimatter
Thanks Raged,
Good deal, hope it works out for ya!
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 02:41 AM
People with NO HeadUnit, Recommand AMP!! camsgs3 Newbie 30 07-26-2004 06:38 PM
2 channel amp to 4 channel SPs zvi General Hardware Discussion 5 02-17-2004 10:46 AM
How do you hook up an amp or preamp(are those the same thing?) ? masch Newbie 1 11-17-2003 03:21 PM
Looking for opinions on Alpine MRV-F450 5 channel amp ShinkunoNamida General MP3Car Discussion 2 09-20-2002 05:57 PM
