Old 05-25-2004, 02:56 PM   #31
bambooracer is on a distinguished road
The mini-phone jack (on the back of your computer) is stereo. The y-splitter will split it into 2 RCA connectors, one for the left channle, one for the right channel.
bambooracer is offline   Reply With Quote
Old 05-25-2004, 05:11 PM   #32
NorthGaVigor's Avatar
NorthGaVigor is on a distinguished road
Quote: Originally Posted by hifiguy
yep, i know what you are saying. i talked to a car audio friend and his only warning for hooking up the amps and pc to turn on together was the following: make sure the pc is on before the amps turn on. reason being that if the amps are on, and then they receive a signal telling them to turn on again, the sound will be distorted.
any thoughts on this? wire a seperate on/off switch?
Huh??? Chicken or Egg?? If you wire the remote turn-on lead (which is the same thing that your power antenna has) to the +12V (yellow) on the PC molex connector then it will ONLY turn ON when the PC is on! PC goes off, +12V goes off, Remote turn-on lead goes off! Simple! If you have any questions don't hesitate to ask. That's the only way you'll learn!
I've been installing stereo systems for money since i was a freshman in high school. We all start somewhere!
See attached NOT FINISHED wiring diagram.
NorthGaVigor is offline   Reply With Quote
Old 05-25-2004, 07:38 PM   #33
hifiguy is on a distinguished road
I decided to use seperate switches for the PC and amps, that way I can power on the the PC first, allow the soundcard to pop, then turn on both amps simultaneously.
Here's my first version of the electrical diagram w/o fuses:
hifiguy is offline   Reply With Quote
Old 05-25-2004, 07:41 PM   #34
maleman876 is on a distinguished road
Quote: Originally Posted by raypsaliga
you could wire the on/off line of the amp to the 12v rail of the computer psu, that way it shuts down with the computer.
or run it to the accessory circuit that cuts on with the car. either way will work.
EDIT: totally missed pages 2 and 3, this has already been mentioned.
maleman876 is offline   Reply With Quote
Old 08-11-2004, 02:19 PM   #35
cyber's Avatar
cyber is on a distinguished road
delete this post please
cyber is offline   Reply With Quote
Old 06-30-2006, 04:14 PM   #36
Sharkbite86's Avatar
Sharkbite86 is on a distinguished road
Ok (resurrecting a dead thread here), i am using an external sound card and a few amps to power my system. The only problem i have is that i cant control anything. I can control things like volume, EQ, L-R balence, fader ect. from the software on my computer but i wanted a hardware solution. I dont like the idea of software controlling my audio system. I have seen various pre-amp/crossovers/EQ indash head units and only take up 1/2 din and they are exactly what i want in terms of control. However, they only provide 2 inputs, and i will require 4-6 inputs and outputs. Anyone have any options? Even DIY build it yourself kits would work for me.
EDIT: an example of what i was thinking about would be the three.1 EQ thing http://www.mobileaudiocontrol.com/pr...50&l1=5250&l2=
But like i said it only has 2 input (has 6 output though...)
MacCar progress:
Planning:-----> [||||||||||||||||||||] 70%
Parts:---------> [||||||||||||||||||||] 0%
Construction:-> [||||||||||||||||||||] 0%
Car broken into... progress is basically zip...
Sharkbite86 is offline   Reply With Quote
Old 06-30-2006, 05:01 PM   #37
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
just so I understand your set-up a bit more
why do you need 6 inputs?
how are you set up that it requires this?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 06-30-2006, 05:44 PM   #38
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
yeah... i assume you want to have 6 inputs to perserve dolby digital/dts?
your best solution in this case would be the alpine pxa-h700 or 701 digital input with all the outputs you are asking for
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 06-30-2006, 07:26 PM   #39
well as scott said i wanted to preserve all the channels im using. I will basically have a 4.1 system in my car. I am planning on installing a mac mini in my car and i was going to connect a Griffin firewave to it to get better surround sound (front LR, back LR, sub).
So it goes:
mac mini----->Firewave-----(front LR, back LR, sub)----->volume, bass, treble, LR balence, EQ controls------>Amps----->speakers and sub
I probably do not need most of the stuff there. All i really need is volume and balance controls (the sub control i can hack off from the wired remote from a powered amp). The rest i can adjust of the computer. Like i said though some kind of diy kit or plan would work too.
MacCar progress:
Old 07-03-2006, 01:45 AM   #40
jemar2169 is on a distinguished road
so where do you get a usb soundcard?, this thread got explained allot to me
jemar2169 is offline   Reply With Quote
Old 07-03-2006, 07:38 AM   #41
_
jemar - are you asking where you can get a USB sound card at?
if so, you might want to rethink this install (unless there's a language barrier here??)
You can get a USB sound card just about anywhere you can buy computer parts.
Do some searching on these boards, I know that I just made a post recently that had about 10 options for USB sound cards.
Jan Bennett
Sound cards from incarpcs , sacrificing sound quality? skinhead General Hardware Discussion 15 09-02-2004 03:05 AM
Carputer to car speakers - how to?? tbird2340 Newbie 29 10-30-2003 02:47 PM
Car with no system..How do I wire the speakers to my MP3 system? fogleroller General Hardware Discussion 10 02-14-2002 03:46 PM
HardDrive SOUND in the speakers !!!!!!! KRyZ General Hardware Discussion 0 03-10-2000 02:19 AM
Can I put Pc speakers on my computer car? prado_sergio General Hardware Discussion 2 08-26-1999 01:11 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
