Old 05-08-2004, 03:22 PM   #1
Loud noice when turning on CarPC
I´ve just finished my CarPC projekt. Unfortunately (but not unexpected ), i´ve got a problem. When i´m turning on my CarPC, the speakers makes a loud noice.
I used the ignition lead to turn on en relay, which turn on both the CarPC and the amps...is this the problem?? What if i used a power-lead from the CarPC to turn on my amp´s? If i could, then i´m sure that CarPC get power before the amps...but would that solve my problem??
//Andreas
Andreas106rally is offline   Reply With Quote
Old 05-08-2004, 04:21 PM   #2
fantomas's Avatar
the noise...is it just a pop? or a constant noise?
rebuilding carpc... kinda..
fantomas is offline   Reply With Quote
Old 05-08-2004, 05:11 PM   #3
It´s just a "POP". When the CarPC is shutting down, there´s no problem...
Old 05-08-2004, 06:31 PM   #4
f150tech's Avatar
Pop eliminators
http://www.davidnavone.com/amp.html
f150tech is offline   Reply With Quote
Old 11-03-2004, 11:27 AM   #5
Or you could use a smiple switch..
I have 2 switches. the first turns on the pc, the second my amps..
TheKingPlaza is offline   Reply With Quote
How2 control CarPC from key fob.... NotchbackVW Power Supplies 1 09-21-2007 05:27 PM
CarPC Software Launcher Confused Software & Software Development 5 05-01-2004 12:10 AM
Help me build the perfect CarPC, suggestions/comments requested... cnugget23 Newbie 1 04-17-2004 03:43 AM
noice when using 12V from cig-lighter loscooby Power Supplies 6 01-01-2004 04:06 AM
Turn on CarPC connected to Opus without ignition switch. Burat Power Supplies 1 12-31-2003 12:30 PM
