Quote: Originally Posted by Motorcity
forgot to mention, you should use an a/b switch to prevent any backfeed through the other input line. this will isolate the input signals, so only 1 line is feeding into your head unit, and the other is just a dead end until you switch to it.
I see. So you think there may be an issue with one source backfeeding to the other even if only one is switched on?
i.e. there may be a problem having the TV on with the PC off as they will both be running into the one line-in. Or do you think a switch will only be required for both sources to live happily together when both on? Basically if I'm using the carputer, wont be able to use the TV - so there's only ever gonna be one on at a time.
PS - many thanks for your replies.
