Go Back   MP3Car.com > Mp3Car Technical Hardware > Car Audio
Old 06-28-2004, 05:14 PM   #1
Gene's Avatar
Gene is on a distinguished road
Question Turn-on amp POP Stoppers
After doing a on how to eliminate two pops from my speakers when I turn my car on, I came across two products:
Stinger's http://www.sfxaudio.com/products/dis...p?ProdId=63361
and David Navone http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-66A
Do you know any other solutions, what are you using?
I have one 4ch amp / 4 speakers. Do I need to get only one item or two (one for each RCA cable)?
Gene is offline   Reply With Quote
Advertisement Sponsored links
Old 06-28-2004, 05:31 PM   #2
ibewslave is on a distinguished road
I have the david navone and it works quite well
ibewslave is offline   Reply With Quote
Old 06-28-2004, 06:07 PM   #3
binary.h4x's Avatar
binary.h4x
Gene i believe that you need one per device that causes the popping noise.
binary.h4x is offline   Reply With Quote
Old 06-28-2004, 06:54 PM   #4
Zac
Zac is on a distinguished road
you only need one...it goes in between the remote wire going to your amp
Zac is offline   Reply With Quote
Old 06-28-2004, 06:55 PM   #5
mutilator's Avatar
mutilator
errrm i just use a standard switching relay...
ignition wire goes through relay to the remote of amp, and is switched by the computers +12v.. that way it dosent power up till after the sound card has started, and powers down when the ignition does.
tom.
Http://www.StairBox.com
mutilator is offline   Reply With Quote
Old 06-28-2004, 08:32 PM   #6
Gene's Avatar
mutilator,
I don't know anything about relays, which one would you recomend: SPST or DPDT
Old 06-29-2004, 12:49 PM   #7
mutilator's Avatar
mutilator
http://www.radioshack.com/product.as...t%5Fid=275-226
that one is similarto mine.
Old 06-29-2004, 01:00 PM   #8
Gene's Avatar
Thanks guys
Old 06-29-2004, 01:02 PM   #9
binary.h4x's Avatar
binary.h4x
Gene you would only need a spst for your amp. How it works it, there is a coil inside and when a voltage goes through the coil, it creates an electromagnet which pulls a little switch inside of the relay. You would run the power from the carputer through the coil and the remote line hooks to the internal switch pins.
Old 06-29-2004, 04:11 PM   #10
ELEmental59437
Some amps have a turn on delay that might be a good solution for some, but my system is personally run with the relay technique. Works great.
ELEmental59437 is offline   Reply With Quote
Old 06-29-2004, 04:57 PM   #11
Gene's Avatar
I'm going to try the relay first. Where does the remote wire go from the relay? Do I need to tap in into existing remote wire going to the amp from ACC? I must be doing something wrong, everything comes on that way but the two pops are still there. Am I way off on this one? Or, do I go from ACC to the relay and then to the amp (haven't tried this one yet) Here is my setup
Old 06-29-2004, 10:52 PM   #12
binary.h4x's Avatar
binary.h4x
the acc line does not go to the amp anymore, you will use the 12V from the relay to trigger the amp.
Old 06-29-2004, 11:02 PM   #13
Gene's Avatar
OK, so the ACC that used to go to the amp now goes to the relay. Thanks
Old 06-29-2004, 11:06 PM   #14
binary.h4x's Avatar
binary.h4x
Old 06-29-2004, 11:12 PM   #15
Top Ramen
lgbr's Avatar
lgbr has a little shameless behaviour in the past
You wouldn't need the ACC line going to the relay would you? Can't you just run +12V from the power supply right to the amp's ACC lead? Or does the time it takes the relay to switch make a difference?
Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
Head units are for cheaters!
Quote:
sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
lgbr is offline   Reply With Quote
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 02:41 AM
car battery Slurpee General Hardware Discussion 35 09-08-2007 05:30 PM
People with NO HeadUnit, Recommand AMP!! camsgs3 Newbie 30 07-26-2004 06:38 PM
Need some help with sending audio to stock amp orangewhip General Hardware Discussion 12 09-04-2003 01:21 PM
amp turn on jasmar General Hardware Discussion 2 07-21-2000 08:51 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
