Old 07-04-2004, 01:50 PM   #1
chris in nh is on a distinguished road
buzz/hum from Lilliput? higher pitch with higher RPMs...
for testing purposes i am running my laptop off it's battery. i have the Lilliput plugged into the cigarette lighter. the Lilliput is connected to the lappy via the VGA cable. the headphone out of the lappy is connected to the AUX IN (rca) of my car stereo. i get audible humming which gets a higher pitch as i rev higher. but when i unplug the Lilliput and just listen to an mp3, i don't hear the humming...
eventually i'd like to power my whole setup from an Opus. i have an email in to them right now to see if i can do it. haven't heard back yet. i don't know if this will solve my problem or not, but the other Opus features would be useful regardless.
i read the 'ground loop' thread below. looks good. just wondering if anyone has any thoughts about possible (easy) fixes...
thanks!
chris in nh is offline   Reply With Quote
Old 07-04-2004, 01:57 PM   #2
Phat Boy
Pudge's Avatar
Pudge is on a distinguished road
The egg is a noisy POS.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
Pudge is offline   Reply With Quote
Old 07-04-2004, 02:02 PM   #3
zijester is on a distinguished road
Its not the egg its the car cig lighter . Get a fuse tap and wire it to the fuse box. I use the radio fuse. That should help.
zijester is offline   Reply With Quote
Old 07-05-2004, 12:22 PM   #4
ok, both answers are a good start.
what if i could hook the Lilliput to an Opus? do you think that would take care of it?
Old 07-05-2004, 12:29 PM   #5
binary.h4x's Avatar
binary.h4x
try adding a couple capacitors in parallel to the power lines going into the lilliput.
binary.h4x is offline   Reply With Quote
Old 07-05-2004, 12:41 PM   #6
flux capacitors?
just kidding. i have no idea how to do that, much less what a capacitor is! can you point me to one, or an install procedure, etc? and when you say 'power lines' which lines are you talking about? (Opus that i plan to install, cig lighter, etc.)
thanks!
Old 07-06-2004, 11:25 AM   #7
Litespeed is on a distinguished road
Run it off the 12V rail on your Opus. Problem solved.
Litespeed is offline   Reply With Quote
Old 07-07-2004, 03:07 AM   #8
WhiteRabbit is on a distinguished road
if you get noise when plugging in the lilliput, thats where your ground loop is. you can reground that, it shoudl help.
next thing, for $20 you can get a ground loop isolator form a stereo shop, it can help sometimes, you can experiment putting it in different places along the signal line, the closer ot the nosie source, the more effective it shoudl be
WhiteRabbit is offline   Reply With Quote
Old 07-10-2004, 12:55 AM   #9
i got an email back from the Opus folks. the Opus unfortunately will not work with my laptop...
so how would i ground/re-ground the cig lighter? sorry, i am completely stupid when it comes to this...
Old 07-25-2004, 04:19 AM   #10
*bump*
i KNOW you guys know the answer!
problem is (alternator/engine) noise on the line. noise seems to be coming from the Lilliput. grounding was suggested, but i'm not sure how...
the Lilliput is currently plugged into the cigarette lighter socket, but i found a source of 12V power (switched and unswtiched) under the center console. it's in case you want to power your phone or other overpriced option. so, assuming i want to use that line, how would i begin to ground such a connection? or can i just ground the Lilliput somehow?
system is Compaq Presario 1688 laptop (K6 - 400MHz, 128MB RAM, XP Pro) - soundcard connects to Becker CDR-220 HU, video connects to Lilliput 7" touchscreen.
thanks!!!
Old 07-25-2004, 07:23 AM   #11
Rub One Out
Motoko's Avatar
Motoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of light
power lili of a 12v line from the Opus.
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 07-26-2004, 12:10 AM   #12
i don't have an opus. it won't work with my laptop. now what?
Old 07-26-2004, 12:15 AM   #13
Clover
Grayscale's Avatar
Grayscale is on a distinguished road
yeah he just said that
i would try grounding your lilliputs negative power wire...or ground to the chassis of your laptop or negative power wire going into it (if you start running it without the battery) just run a wire between the two negative power wires...
CarPC install is starting to come along again...
Grayscale is offline   Reply With Quote
Old 07-26-2004, 12:25 AM   #14
awesome! how?
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
