Old 07-05-2004, 10:05 AM   #1
masch
how about this: grounding produces noise
I was reading the other thread about grounding the lilliput vga connector to reduce the flickering. So as we know the vga connector attaches to the VGA port of the computer case, hence all around that area would be ground.
I checked the resistance between there and my car body (actually to one of the screws that bolts my seat to the car body) and found it to be around 4 KOhms. I thought, hrmm, that's too high.
So I ran a wire from the screw-bolt to the vga connector and attached it to the vga prot screw, and found the resistance to be about 3 ohms. (voltage difference between the screwbolt and the vga connector about 0.15V)
But now.. I get alternator noise! Which wasnt there before (maybe it was but I didnt notice it). It didnt fix the lilliput flickering either.
Possible problems?
1) That screw-bolt is not really car body
2) difference in potential between amplifier to CPU, or between preamp to CPU
3) quite lengthy ground wire (about 20 cm)
4) ground wire is quite narrow in diameter, about 1/3 the diameter of the power wire.
Hrmm, I could fix this problem by just removing the ground wire, but I dont want to hide the problem.. i wanna fix it for real
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 07-05-2004, 10:14 AM   #2
Raw Wave
Confused's Avatar
Confused is on a distinguished road
The problem is that you've now introduced yet ANOTHER ground point into your system. You've got the PC ground, the lilliput power ground, plus this ground from the vga connector.
Wire up the power of the screen to the output from your PSU, and make sure that is grounded, and you should be fine.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 07-05-2004, 12:29 PM   #3
masch
I dont think the lilliput is grounded at all before this connection.
The PC case wasnt grounded either. It was when I grounded the PC case together with the lilliput that I get this problem.
By your suggestion, you mean the output of my PSU should go to my mobo and my lilliput? The excalibur chip I use to moderate the 12V incoming voltage is rated at 1.5A I believe, and I think the cpu is using a lot of that juice already
Old 07-06-2004, 07:39 AM   #4
mutilator's Avatar
mutilator
heh my bros install, we wired the pc +12v, before the -12v, and it started up anyways.. (must of been grounding through VGA) took a while to figure why the picture was so flickery etc (id assumed hed grounded it, he assumed i had...
its best to ground everything in 1 place as far as i know.
tom.
Http://www.StairBox.com
mutilator is offline   Reply With Quote
Group buy for the cheap MagicPower 120W MPD-810H DC-DC PSU Telek Power Supplies 86 04-04-2005 04:57 PM
Damn Noise Freeman General Hardware Discussion 3 03-20-2004 01:37 AM
need some noise help spyhunter General MP3Car Discussion 6 07-20-2003 11:20 PM
my wrestle with alternator noise. Cliff General Hardware Discussion 88 04-02-2003 06:55 AM
Questiong about noise filter helloman General Hardware Discussion 7 11-05-2001 09:18 AM
