Old 07-08-2004, 01:15 PM   #1
Nicholasp27
Best audio solution for me?
I'm going to use a travla c134 case with epia m10000 motherboard. i'd like to output the sound via rca's directly from the carputer to my component amp and my sub amp...
should i get a usb soundblaster, usb m-audio, extigy, use the mobo's outputs? sq is important and i'll be having the carputer replace my hu and do everything it did (fm, cd) plus mp3s, navigation, tv, dvds, etc
i'd like it to be powered directly from the epia...i'll be using one of those new cnx-p1260 60 watt dc-dc psus, so power consumption of the different options may be an issue...
what's the best sounding solution?
what's the best value solution (sound per $)?
thanks
Nicholasp27 is offline   Reply With Quote
Old 07-08-2004, 02:36 PM   #2
brandon is on a distinguished road
I have your exact setup with the exception of me using a morex case, I'm also a SQ freak.
I plan on purchasing a PCI Audigy2, I see them on ebay in the $50-$100 range, the USB probably costs about the same.
from everything I have read, listened to, and gathered from speaking to my friends it is a great soundcard, and has been mentioned alot on these forums. And if I recall correctly it has 4v preout which is a big plus when hooking it directly to an amp.
brandon is offline   Reply With Quote
Old 07-08-2004, 03:22 PM   #3
Raw Wave
Defiler's Avatar
Defiler is on a distinguished road
Are you sure on the preout for that Audigy card. I thought it was a lot less.
Defiler is offline   Reply With Quote
Old 07-08-2004, 03:34 PM   #4
that's why I made the comment "If I recall correctly"
I was planning on doing a search just to doublecheck myself, but I don't know why I would have that in my head if I didn't read it somewhere.
OEM Navigation Connectors Mr Castulucci General Hardware Discussion 14 07-22-2007 05:31 PM
Carputer integration with HUGE car audio system, help please septicdeath Newbie 19 12-04-2004 06:37 PM
Seperate VGA and S-Video with Audio Fox_Mulder General Hardware Discussion 7 07-01-2004 02:44 AM
Who wants an Audio Forum on mp3car.com? Banderon Mp3car Forum Suggestions/Comments 25 04-15-2004 10:19 AM
audio interface (direct comp-> car audio sys) Noble Newbie 5 02-29-2004 08:18 PM
