Uncommon to me, but I'm sure others have seen it before. I feel automotive manufacturers should keep out of the audio industry and let others take care of it for themselves. or at least contract some real experts to design the systems... anyhow.
It's very common to run more than one speaker or set of speakers on each channel of an amp.
In parallel wiring, which if the speakers are identical, would halve the impedance, dividing the channel's power between the speakers.
If you have two 4 ohm speakers and wire both directly to the single channel of an amp, the amp will see a 2 ohm load, and divide it's 2 ohm rated power between the two speakers, giving each speaker the amp's full 4 ohm rated power. (or close to it. keep in mind there are other factors like efficiency and loss to heat)
I'd assume you could run the tweet and the mid to the same channel, but hopefully someone who has encountered this will chime in.
Time for me to go to work.
