I just finished (last weekend) this same setup with a 2001.
Remove the HU, and put the screen in that spot. Then use the dlink FM USB for the radio. BUT... big but here... get the motorola female antenna plug from Radio shack, use some cat5 cable (twisted pair for the inheriant interference elimination) and wire the center pin of the motorola to the outside shield of an RCA male plug. Then wire the shield of the motorla to the center pin of the RCA. Use one pair of the cat5 and leave as many twists as you can in place.
I get better reception in this setup than I did with the original HU.
Then wire the computer to a new amp (I got a phoenix gold - awesome!!! If you guys haven't heard of cbrstereo.com go there NOW!!).
I left all the stock speaker wire in place, and got a HU adpater and ran new wire to that, and plugged the adapter into the stock wiring harness.
Took 3 days to make everything, including a replacement tray out of plexi where the HU used to be.
Used a compaq laptop under the passenger seat, hid all the wires, and used an iGo power adapter for the laptop.
I took apart the laptop, and wired in an external power switch to the touchscreen power switch... The amp I got has anti-thump built in, so I turn on the computer manually as I enter the car.
Hardest part of the whole install - pulling off the damn dash!!
