Closed Thread
Old 07-26-2004, 10:52 AM   #1
David88vert is on a distinguished road
need a digital input on amp
I need an amp with a digital input since my laptop has a digital output. Anyone know of any? Preferably 5 ch.
David88vert is offline
Old 07-26-2004, 11:11 AM   #2
DjBac's Avatar
DjBac is on a distinguished road
Try a DAC or processor!!
DjBac is offline
Old 07-26-2004, 12:42 PM   #3
The whole purpose is to keep the signal truely digital as long as possible - all the way to the amp. A DAC defeats the purpose. If I have to convert, I would rather go to optical and find an amp with an optical input.
Old 07-26-2004, 01:03 PM   #4
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Then Google it.
antimatter is offline
Old 07-26-2004, 01:10 PM   #5
Zip-Lock is on a distinguished road
Here you go http://www.cardomain.com/item/PHOR51MT
I ordered one this morning to test out. It looks like it should be ideal for people considering doing away with a head unit yet still having good control over their speakers. It has on screen programming, optical in, and coaxial in.
Zip-Lock is offline
Old 07-26-2004, 01:25 PM   #6
Jesus Freak
antimatter's Avatar
That looks pretty nice. Not too bad of a price either. I wish it had a little bit more power at least on the subwoofer channel.
Old 07-26-2004, 01:41 PM   #7
MrPerfectionest is on a distinguished road
What do you think is happening inside the amp? In theory a self contained unit should be better than two seperate units but if the amp is using poor DACs itself then performance will suffer. You could also argue the case that the DACs inside the amp are using the same power supplies as the rest of the amp which could introduce undesirable sonic effects.
In fact, I will go out on a limb here and say a dedicated DAC plus good amplifier will sound better than almost all other DAC + AMP combos for a similar amount of money out there.
MrPerfectionest is offline
Old 07-26-2004, 04:06 PM   #8
MrSpace is on a distinguished road
I also think a good DAC and a good amp will sound better. You can send the signal with a fiber optic or high end digital cable and then use high end RCA to send to the amp (as close as possible to the DAC).
Altough Phoenix Gold makes really good amps, they aren't as good since their head engineer is now in a new co. called Concept.
Plus when having a separate DAC, you can then send your signals to many amps, controlling perfectly the power you want for your components.
Etienne
MrSpace is offline
Old 07-26-2004, 05:12 PM   #9
DjBac's Avatar
In my opinion and experience Alpine's PXA-H900 is one of the best processors that can do the job!!! It also has 11-ch outputs!!!:P:P
DjBac is offline
Old 07-26-2004, 07:42 PM   #10
your'e talking about the top of the line
if you have th emoney, that's the best you can get!!!
Etienne
MrSpace is offline
Old 07-27-2004, 11:57 AM   #11
Thanks, that will do the job. We don't sell PG, so I hadn't looked at them. Picking them up soon though.
Old 07-27-2004, 12:02 PM   #12
Of course it is being converted inside the amp.
The performance will not suffer to a point that you could every hear it. You could only measure it at best.
This car has a limited amount of space, and a lot of other items being installed in it, so space is at a premium. The PG amp that he listed will do the job just fine for this application.
Old 07-27-2004, 12:03 PM   #13
Can't afford that one. Too much for my blood, but I am probably using it in one of our show cars soon.
Old 07-27-2004, 01:01 PM   #14
DjBac's Avatar
Etienne
I am trying for the last 50 days to find it!!! Do you know a dealer that could have it???
Can this co-operate with an audigy's optical output??? Is it toshlink compatible??
DjBac is offline
Old 07-27-2004, 03:56 PM   #15
You didn't indicate this as a reason for needing a single unit.
Closed Thread
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 03:41 AM
For those who want true 5.1 Dolby Digital and DTS antimatter Car Audio 89 06-29-2007 12:54 PM
Digital Amp turbopropper Car Audio 7 07-07-2004 03:34 AM
DSP/EQ with a digital input (repost) belezeebub General Hardware Discussion 0 03-24-2004 07:20 PM
amp with digital input? etrik General Hardware Discussion 3 05-08-2002 07:15 AM
