I think he is referring to a fm transmitter/modulator; the dsbr100 is a fm tuner...Modulators/transmitters are known to be subpar to aux in jacks on headunits or direct connections to amps, but you should be able to go to any car stereo store and get an inline modulator, or you can go to walmart and buy an fm transmitter (does not directly connect to antenna line); both will do the job, and a modulator will work better, but neither will work as well as the direct connections to the hu or amp...
