The MP3car.com Store
Thread Tools Display Modes
Old 08-29-2004, 05:20 PM   #16
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
Quote: Originally Posted by slasherx
Should I have the isolators next to the Audigy or have them connecting to the RCA inputs on the AMP?
Doesn't matter, anywhere in that lead is fine.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Sponsored Links
Old 08-29-2004, 05:21 PM   #17
My Photos: (0)
Hm then I'm all out of ideas.
slasherx is offline   Reply With Quote
Old 08-29-2004, 11:00 PM   #18
My Photos: (0)
Basically if I buy an opus will it eliminate the alternator whine? Also how would I be able to power the audigy 2 nx?
Old 09-01-2004, 04:35 PM   #19
My Photos: (0)
Nobody has any input?
Old 09-03-2004, 07:15 PM   #20
My Photos: (0)
Well I moved the ground loop isolators next to the rca inputs on the amp as opposed to being with the computer in the front, and it cleared up the alternator whine!
Sponsored Links
Old 09-09-2004, 01:33 AM   #21
PaCMaYNE's Avatar
Vehicle: 2000 Mercedes C230
My Photos: (0)
weird,, im gonna have to get some GLI's then,, radioshack?
throw a moon
heuvos vin chevos
PaCMaYNE is offline   Reply With Quote
Old 09-09-2004, 02:06 AM   #22
My Photos: (0)
yup
Old 09-09-2004, 03:35 AM   #23
PaCMaYNE's Avatar
My Photos: (0)
ok damnit
ive read EVERY damn noise thread,, and just like the whole back and forth ****tle between the FM mod,, or tape acc battle,,,,,, there seems to be no "best solution"
here are my simple probs,, which i guess im lucky with as i just hooked it up ,,, finally
1- Fuzzy lines on the lilli,,,, which since im using the egg into the ligher im guessing is the prob..... i ran an extra power cable JUST IN CASE this happened from the battery,,,as my battery is in the trunk(mercedes)
¤solution¤--- hard wire the cable into some acc on the fuse box,, and ground as close as possible
2- Of course,, alternator noise,, and hums,, half is from the ****ty FM MOD,, which i already know the sounds of that,, using a ext cd player i can hear those,, slightly,, so i know those probs,, alternator noise though,,,, ive read loop iso's "yea dude they pwn,, get those" as well as " no mayne just fix your grounds,, thats all it is" all my grounds are deeply covered,,,, the little few i have (PSU, FM mod, i think thats it) but My PSU is grounded very close to the battery ground BUT even when using a EXTERNAL AC-DC pSU from the house,, i hear it,, im guessing the grounding of the LILLI is the prob,, im so stupid i have yet to unplug the VGA cord and try that,, its all aprt now,, and 3:36 AM,, so im shooting for what little time i haev to work on it tommorrow and know what im gonna try...
3- My damn MOrex CAR PSU,, not powering my HD,,, Something il have to test with a multimeter i presume,, which i dont have...
so main fixes,,
¤ hard wire lilli (with? or without? egg)
and hopefully thatll fix my Lilli lines and Alternator noise
any comments suggestions??
BTW,, i have a wooden case so no grounding of the case,, and no PSU case,,
throw a moon
heuvos vin chevos
Old 09-09-2004, 04:11 AM   #24
PaCMaYNE's Avatar
My Photos: (0)
wow
update,, i weent out there at 4 am as it was ****ing me off and i wanted to prove my theory,, and its true,, the lilli made nasty noise feedback,, looks like im hardiwiring tommorrow,, ill still use the cig positive but the chassis as the negative,, word to all if you have radiator noise,, check your LILLI wiring!!!!!!!
hope it removes the nasty lines as well 8-D
now for that damn PSU
throw a moon
heuvos vin chevos
Old 09-09-2004, 04:50 AM   #25
bertybassett's CarPC Specs
bertybassett's Avatar
Vehicle: VW Beetle (lhd)
My Photos: (0)
does any one have an on-line link for this item?
Travla C134 case with M1-ITX (new firmware)
Nehemiah EPIA M 10000
256mb memory
20GB H/D
eBay GPS unit
Ninja monkey's Desintator 3 client frontend
Frodoplayer
7" lilliput touchscreen
bertybassett is offline   Reply With Quote
Old 09-09-2004, 05:20 AM   #26
PaCMaYNE's Avatar
My Photos: (0)
you dont need it
CHECK YOUR GROUNDS!!!!
throw a moon
heuvos vin chevos
Old 09-09-2004, 06:02 AM   #27
cheap custom title
JC-S60's CarPC Specs
JC-S60's Avatar
Vehicle: 01 Renault Espace BiFuel | Mitsubishi Canter | BMW R1200GS Adventure | Yamaha YZF600R | Honda CB650
My Photos: (0)
You should use the egg, as it regulates the 12v to your screen.
It will work without, but can break easily, as your car's voltage can spike up to 16v.
JC-S60 is offline   Reply With Quote
Old 09-09-2004, 06:04 AM   #28
cheap custom title
JC-S60's Avatar
My Photos: (0)
In fact, using a wooden case lets interference in the computer AND lets the interference generated by the computer get out into the car.
I would cover the case with aluminium foil on the inside and ground it.
Old 09-09-2004, 05:28 PM   #29
PaCMaYNE's Avatar
My Photos: (0)
well i grounded my cable AFTER the regulator egg and every last bit of noise i had,,,, went away.
throw a moon
heuvos vin chevos
Sponsored Links
vB code is On
Trackbacks are Off
Group buy for the cheap MagicPower 120W MPD-810H DC-DC PSU Telek Power Supplies 86 04-04-2005 03:57 PM
Got some humming/buzzing noise out of stock system Bxscig General Hardware Discussion 17 07-31-2004 02:39 PM
Request regarding the Offical Skin Presentation thread Confused MediaCar 3 01-07-2004 11:52 AM
need some noise help spyhunter General MP3Car Discussion 6 07-20-2003 10:20 PM
Power noise - the horror!!! mtmsol Power Supplies 3 06-19-2001 09:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
