The MP3car.com Store
Thread Tools Display Modes
Old 09-09-2004, 07:57 AM   #1
tbird2340's CarPC Specs
tbird2340's Avatar
Vehicle: 2005 Dodge Ram Quad Cab
My Photos: (0)
Noise coming through speakers - Help Needed
Ok. I've searched but none really helped me.
My setup is as follows:
M10000 Onboard Sound > Stereo Jack split into RCA's > RCA's to Connector > Connector to Other Connector > Head Unit AUX In port. I have a PW70A w/ ITPS.
I'm not sure what "Alternator noise" is or not so I don't know if that is what my problem is. Everything works fine in my setup except the noise. I only get the noise when my HU is in AUX mode. The louder I turn my radio up the louder the noise. The noise doesn't seem to change when I accelerate.
I have my ITPS hooked into the remote wire of my head unit.
Please help with some ideas of what I can do. Thanks
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Sponsored Links
Old 09-09-2004, 08:00 AM   #2
Super Moderator
hijinks21's Avatar
Vehicle: 98 Exporer Sport
My Photos: (0)
make sure everything is grounded to the same point in your car. psu/case/mobo/amps.. etc
'98 Explorer Sport
80% done
hijinks21 is offline   Reply With Quote
Old 09-09-2004, 08:33 AM   #3
tbird2340's Avatar
My Photos: (0)
Really? I have things grounded all over the place. Well not really I guess... I mean how many ground wires are there actually? I don't use amps so there would be:
1. ITPS (and the PW70A PSU ties into the ITPS ground)
2. The Lilliput EGG (but I wouldn't think that has anything to do w/ the audio)
Is that it??
Thanks for the help!
Old 09-09-2004, 09:50 AM   #4
Super Moderator
hijinks21's Avatar
My Photos: (0)
ya try grounding your pc case to the same spot as your itps.. if you ground it to your car frame.. if you have too many grounds all over the place you create a ground loop which will create noise.. you can buy a ground loop isolator that sits on your rca lines.. but i'd rather ground correctly then mask the real issue.
but try a simple ground on your pc case first
'98 Explorer Sport
80% done
Old 09-09-2004, 10:00 AM   #5
microbionic's Avatar
Vehicle: 2002 Mazda Protege
My Photos: (0)
the egg thing has had some problems in the past for noise,,
microbionic is offline   Reply With Quote
Old 09-09-2004, 10:10 AM   #6
tbird2340's Avatar
My Photos: (0)
My case is made out of plexi. How would I ground that?
Old 09-09-2004, 04:45 PM   #7
tbird2340's Avatar
My Photos: (0)
Now that you say that... I had noise BEFORE I hardwired my Lilli but now that my Lilli is hardwired (tapped into my radio's ACC wire) I am getting a lot more noise.
Please help!
Old 09-09-2004, 04:48 PM   #8
Whistle Tip
pimpJ's Avatar
Vehicle: '02 Chevy Cavalier (Woot!)
My Photos: (0)
I had a problem with grounding too. I dont have the PC in yet, but just with the stereo and amp.
just make sure you don't have a ground loop. Ground them in the same spot
pimpJ is offline   Reply With Quote
Old 09-09-2004, 06:06 PM   #9
tbird2340's Avatar
My Photos: (0)
Ground WHAT in the same spot though? I don't have a metal case so how would I ground the "case". What other ground wires are there besides the ITPS/PSU?
Old 09-09-2004, 06:50 PM   #10
Super Moderator
hijinks21's Avatar
My Photos: (0)
try grounding your case to the frame of your care.. take a o-ring and connect it to some wire and then put the oring around a casr screw.. tighten the screw then find a spot to screw the other side to your frame
'98 Explorer Sport
80% done
Sponsored Links
Old 09-09-2004, 06:54 PM   #11
PaCMaYNE's Avatar
Vehicle: 2000 Mercedes C230
My Photos: (0)
ok,, i have found in the last week,, the lilli is where the noise is derived from,,,,mostly
one you shoud ground your vga shielding on your cable,, tot he chassis,, that will eliminate nearly all of the alternator noise,, but most likely afterwards still hear a slight bit of it.....casused from the "egg" theres no way around this,,, i tried capacitors,GLI's ect,, then i grounded AFTER the egg,, and crystal clear 8-)
throw a moon
heuvos vin chevos
PaCMaYNE is offline   Reply With Quote
Old 09-10-2004, 06:52 AM   #12
tbird2340's Avatar
My Photos: (0)
OK... A couple things.. With the Carputer totally off and with no power whatsoever going to it I still get the noise. Does that mean that it's NOT the PC?
Also, hijinks, do you mean for me to take an O ring and attach it to a MOTHERBOARD screw? Like I said.. I don't have a metal case. Look:
PaCMaYNE, isn't that dangerous to not use the egg? Isn't it on there to regulate the power going to it? I don't want to be frying my Lilli.
Thanks for the help.
Old 09-10-2004, 06:56 AM   #13
My Photos: (0)
yes it is dangerouse to not use regulated power, use regulated power, just not from the "egg",
Old 09-10-2004, 07:13 AM   #14
tbird2340's Avatar
My Photos: (0)
Should I hard wire it into the PW70A then?
Old 09-10-2004, 07:18 AM   #15
no1knows's Avatar
Vehicle: 94 Honda Civic LSi Hatch
My Photos: (0)
yeh, run it off your PSU's 12v rail.
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
no1knows is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
92 range rover speakers cutting out MAXXMODDER Car Audio 1 12-09-2005 04:40 PM
Motherboard fan noise in speakers JayKaye Car Audio 9 05-09-2004 07:12 AM
need some noise help spyhunter General MP3Car Discussion 6 07-20-2003 10:20 PM
Hard disk interference noise. (long) MikeHunt79 General Hardware Discussion 22 07-01-2003 06:28 PM
Funny noise coming out of speakers... SuperMatty General Hardware Discussion 6 03-17-2002 10:01 AM
Sponsored Links
Ad Management by RedTyger
