Quote: Originally Posted by JC-S60
on a sidenote, antimatter, put a small cap in front of any device that acts strangely to power fluctuations/noise. It helps a lot!
And does your power supply put out 16v when connected to the converter too? Those cheap supplies can drop very easely some volts under load.
Looks like i missed this one...
Yea... the power supply puts out enough voltage\amperage... it is actually a power supply for using your 16v laptop off of the cig lighter.
The really strange thing that is going on with the M-Audio C02 is that it will only work when the Positive line is plugged in..thats right only the + and the negative line is connected to nothing, freekin strange if you ask me. But it still doesn;t work perfectly. i.e. it has the cracking and so fourth.
I will probably try a capacator for good measure. If nothing works i will probably go back the cheapo ebay crap and maybe power it off my power supply, that or build my own circuit.
This crap is frustrating. You think it would be simple to convert coax to optical
