The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 09-12-2004, 11:13 AM   #1
EBFoxbat's Avatar
Vehicle: 2004 GMC Canyon 4x4 Z71 Reg Cab
My Photos: (0)
Intigrated Amp
I'm making my carputer completely removeable. The only connection to my car will be a 12v line from the battery and a ground. And even that is going to be hidden and made to look like a cigarette lighter.
Everything, drives, mobo, screen, is to be mounted in a box. I'm considering putting a tiny (low power and physically small) amp in the box along with some 6" speakers (maybe 5 1/4" depending on room).
I know there'll be a heat issue, but will the driving speakers and amp make too much noise on my system?
Is this a stupid thought and I should abandon it now?
'04 Canyon 4x4 pickup
[---PC on hold----working on external fiberglass "tool" box---]
EBFoxbat is offline   Reply With Quote
Sponsored Links
Old 09-12-2004, 02:32 PM   #2
EBFoxbat's Avatar
My Photos: (0)
Anyone?
Old 09-12-2004, 02:57 PM   #3
choyak's Avatar
Vehicle: 2004 Toyota 4Runner SR5
My Photos: (0)
That would only work if you use EPIA or some small motherboard, and isolate the HD from the speaker vibration. Wouldn't it be very huge, though considering speakers, amp, LCD in there. It is great to prevent from getting jacked, however. It also would need a couple of fans like 80cm to cool the amp and HD
Carputer currently 'ghettoed' into car!!!
EPIA MII-12000
Ampie Case with rigged extra USB
Hitachi 60GB
Holux GPS mouse with iGuidance 2.0
Lilliput 7" touchscreen
Netgear WG121 USB WiFi
Carnetix P1260
choyak is offline   Reply With Quote
Old 09-12-2004, 03:03 PM   #4
cheap custom title
JC-S60's CarPC Specs
JC-S60's Avatar
Vehicle: 01 Renault Espace BiFuel | Mitsubishi Canter | BMW R1200GS Adventure | Yamaha YZF600R | Honda CB650
My Photos: (0)
erm, laptop?
Seriously, this sounds nice. Maybe use the amp of some amplified speakers, which usually work at 12v.
JC-S60 is offline   Reply With Quote
Old 09-12-2004, 03:22 PM   #5
EBFoxbat's Avatar
My Photos: (0)
Yup, laptop motherboard. 2.5" HDD and a USB DVD drive... I should have room. Think there is EMI problems ?
Old 09-12-2004, 03:26 PM   #6
cheap custom title
JC-S60's Avatar
My Photos: (0)
What case are you going to use? If it isn't metal, put some tin foil on the inside and ground it. If you notice interference, you can still put some metal sheets between different parts and ground them.
Definately show us some pictures!
Old 09-12-2004, 03:28 PM   #7
EBFoxbat's Avatar
My Photos: (0)
I'm thinking I might isolate the speakers in a metal box for EMI and to cut down on vibration. It's not going to be a very high power system, I'm not looking for 15" subs or anything. Probably some good-quality 6" speakers.
I figure it's more modular and better quality than my stock HU/speakers and an FR modulator.
Do the moving elements in a speaker's megnets cause much EMI ?
Old 09-12-2004, 03:35 PM   #8
cheap custom title
JC-S60's Avatar
My Photos: (0)
Well, a speaker uses electro-magnetic fields to move the conus. So yes, there will be a field. It might be enough to ground the metal (check with a multimeter it isn't connected to one of the poles).
Old 09-12-2004, 04:10 PM   #9
MySQL Error
jcdillin's CarPC Specs
jcdillin's Avatar
Vehicle: 2002 Dodge Ram 1500 Quad Cab
My Photos: (3)
as long as you put metal around the speakers should keep most the magnetic field inside. Last time I pulled a computer apart that had speakers mounted inside they were setup that way.
jcdillin is offline   Reply With Quote
Old 09-12-2004, 06:20 PM   #10
EBFoxbat's Avatar
My Photos: (0)
Does it have to be a solid metal box or would a cage work?
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 02:41 AM
People with NO HeadUnit, Recommand AMP!! camsgs3 Newbie 30 07-26-2004 06:38 PM
Amp setup. Heat concern. d_sellers1 Car Audio 2 07-09-2004 09:58 AM
Having problem with AMP, need HELP!! ryuandwings Car Audio 31 05-01-2004 07:31 PM
EPIA M9000 connection to car amp wi77iam General Hardware Discussion 2 08-08-2003 01:37 PM
Sponsored Links
Ad Management by RedTyger
