Go Back   MP3Car.com > Mp3Car Technical Hardware > Car Audio
Old 09-20-2004, 01:28 PM   #1
Sporttracguy's Avatar
Sporttracguy is on a distinguished road
How to boost radio reception??????????????
ever since i put in my new Head unit the radio reception hasnt been as good as my stock system.. is there a way to boost the signal? something i can plug in or something? any help would be great, thanks
Sporttracguy is offline   Reply With Quote
Old 09-20-2004, 01:37 PM   #2
Jesus Freak
antimatter's Avatar
antimatter will become famous soon enoughantimatter will become famous soon enough
whoaa fella, go easy on the question marks. Why don't you try using the search feature of this website. Do a little reading and get back to me. The answers are out there.
Must you be spoon fed?
antimatter is offline   Reply With Quote
Old 09-20-2004, 01:37 PM   #3
kingtut is on a distinguished road
I have same issue, had to get an aftermarket unit -Pio- to be able to use an AUX-IN, but the reception sucks specialy for AM (1010wins news & traffic), the AM signal keeps fading in & out. I did some search and found that it is common for aftermarket units not to be as good as stock when it comes to tuner reception. You got to hand it to the car guys, they do make good tuners!
kingtut is offline   Reply With Quote
Old 09-20-2004, 01:38 PM   #4
mindscream's Avatar
mindscream is on a distinguished road
Radio Shack used to have an antenna booster, but I checked today and they didn't have one on their website. It seems that anything that's useful Radio Shack has stopped carrying...
I guess they didn't like those techie types coming in who knew more about their products than the idiots behind the counter.
If you did a for Car or Auto Antenna Signal Booster you should be able to find something.
Found one here from google
http://www.electronixwarehouse.com/c...s/boosters.htm
Mind Scream out
mindscream is offline   Reply With Quote
Old 09-20-2004, 02:25 PM   #5
Thanks guys, ill check it out.. anyone had any experience with these antenna boosters that work?
Old 09-21-2004, 06:19 PM   #6
Comp-guy is on a distinguished road
No Joy
I've had bad luck with boosters. My wife's stock tuner could be stronger, so I bought one. I can't tell any difference.
I E-mailed a bunch of people who bought them on E-bay and asked how they faired, thinking maybe I bought the wrong one. They all wrote back with similar stories to mine - little or no improvement, not matter what brand they bought.
Just my 2 cents worth.
Good Luck
Status:
Selling my equipment
Comp-guy is offline   Reply With Quote
Old 09-21-2004, 09:38 PM   #7
Jailer is on a distinguished road
Try a weingard booster if they're still in business. It's the only one I've seen that actually worked. Be prepared to pay for it though, last I knew they were running in the neighborhood of $50, but that was 11 years ago. Might be able to find one on e-bay if they went under or aren't making them anymore. One thing, it will not help with AM reception, it's an FM booster only. AM & FM signals travel differently, AM Travels in a straight line (hence why you can pick up AM stations at greater distance than FM) where FM doesn't (Why FM isn't affected as badly by large object in it's path like skyscrapers). A booster also will not help if you are not receiving any signal, it will only boost what's there.
Jailer is offline   Reply With Quote
Old 09-25-2004, 11:49 AM   #8
Joe_Collectible's Avatar
Joe_Collectible is on a distinguished road
if your inputting bad reception, your going to boost bad reception. Maybe not a signal booster, but a better antenna? http://www.antennax.com/ (OEM stuff mostly) - can't go wrong when their homepage shows a fast and furious logo :/
Pre-amp and Boosted signals are diff
This good artible to read: http://www.termpro.com/articles/antenna.html
Ghetto Sleds Turn Heads
PimpED OutneSS ProGress O' MetER
¿--22%--------!
(still noobin')
Joe_Collectible is offline   Reply With Quote
Old 09-25-2004, 12:18 PM   #9
The thing is,, my reception with the OEM head unit was great so the antenna should be fine, when i put the pioneer in the reception just isnt as good. I have checked the connectiong many times from the antenna to the head unit and its installed correctly,, not sure what else to do.. we will see if this booser i ordered helps.. ill keep you all posted
Old 09-27-2004, 07:30 AM   #10
That's unusual, Pioneer used to have excellent tuners. We used to recommend them to people with reception complaints because of it. Not to say that they couldn't have changed their tuners. Try a booster, but I doubt it will help much. How far away are the stations you're trying to pick up? You might try testing the antenna before you invest in a booster, you may have an intermittent connection somewhere. To Test it take an ohm meter and connect one end to the center pin on the antenna, connect the other to the antenna whip (you may have to unscrew the whip and connect it to the whip stud). You should have Zero resistance. Next connect one end of the ohm meter to the ground side of the antenna, that's the fatter metal part of the antenna connector, connect the other end to ground. Again you should have zero resistance. If you have any resistance at all it's usually on the ground side of the antenna and you should consider replacing the antenna. One last test, make sure there is no connection between the + and - sides of the antenna connector, if there is your antenna is shorted and no good.
Old 09-29-2004, 02:50 AM   #11
Bigmaxxin's Avatar
Bigmaxxin is on a distinguished road
yeah i thought the pioneers have the super tuners, cause i have a pioneer with this technology, and i can get radio signals from places like chico, (i live in sac) and modesto.
Bigmaxxin is offline   Reply With Quote
Old 09-29-2004, 02:44 PM   #12
zPilott's Avatar
zPilott is on a distinguished road
my problem is with the fm modulator. I thought it would jsut be a pass through when it is turned off, but it affects my reception. If I have the antenna plugged straight into the HU the reception is fine, but when I go through the modulator, with the switch off, the reception is reduced.
Does anyone know of an input selector that has antenna jacks? maybe I could solve my problem if i bypassed the modulator alltogether.
|V1 Virtual Display|
Hard work often pays off over time, laziness always pays off right now.
zPilott is offline   Reply With Quote
Old 10-02-2004, 03:20 PM   #13
Turns out it was the RF modulator. connected the antenna directly to the head unit and it fixed the problem,, i think its odd that i didnt notice it with the stock unit though. the pioneer has aux inputs so i wont need the RF modulator anymore,, good thing lol
Old 10-02-2004, 08:01 PM   #14
zPilott's Avatar
must be nice!
|V1 Virtual Display|
Old 10-03-2004, 01:30 AM   #15
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Most of you replace an original radio with the after market one and having radio reception problem (suck on AM), the change is that your car antenna is powered. You need to feed power to the antenna. Usually the antenna and its "power" wire join together about 1-2 feets after the harness and antenna plug.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Class 2 Data Bus owenjh Engine Management, OBD-II, Engine Diagnostics, etc. 35 10-09-2008 03:34 AM
TM-701L converted Lilliput causes radio interference archimense LCD/Display 16 07-04-2004 08:14 AM
How do i make Radio working in MediaCar? zvi MediaCar 0 05-16-2004 02:38 PM
AM radio reception?? judoGTI General Hardware Discussion 1 03-02-2004 09:14 PM
usb radio, d-link reception sucks ***... bankingdom General Hardware Discussion 0 09-16-2003 11:58 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
