The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 09-25-2004, 03:20 PM   #1
Vehicle: 2002 laguna
My Photos: (0)
Sound not very loud have i bought the wrong amp
My carpc sound is not very loud.I am running a Creative Labs SoundBlaster Audigy 2 NX Sound Card and a sony 4 X 19 watts rms per channel amp. I have no HU.
After reading loads of theads all i can come up with is that the sound card doesn't put out much power into the amp to start off with and so the amp can only amplifier so much.
1. Is the amp the wrong type, like expects high power in like from a head unit to get a louder sound out of the amp.
2.Do I have to use my sound card to my sony amp and use it as a line driver and then go into to another amp to power my 4 channel speakers.
3. Do I buy another amp that will take a low power input from my sound card.
Thanks for any help.
rickyaswell is offline   Reply With Quote
Sponsored Links
Old 09-25-2004, 03:38 PM   #2
ppgt94's Avatar
Vehicle: MKIV VW Jetta
My Photos: (0)
1. If you used RCA cables to for input it's probably low-level (not amplified).
2. I don't know. Read the manual if you have it or check @ sony.com.
3. If your amp doesn't accept low level input then it would be the easiest solution.
But first check the gain level on the amp.
ppgt94 is offline   Reply With Quote
Old 09-25-2004, 03:47 PM   #3
Vehicle: 2000 Chevy Silverado Z71
My Photos: (0)
Pick up a line driver to increase the output of the soundcard. Should solve your problems if it's a low signal level problem. Might want to consider a bigger amp anyway, 19W isn't a lot of power.
Jailer is offline   Reply With Quote
Old 09-25-2004, 03:59 PM   #4
My Photos: (0)
No it doesn't have RCA inputs just wires in and out, its just plugs in between my old stock radio and speakers the amp expects high power in.
So all i have to do is get rid of it and get an amp with rca (low level) and plug my sound card into that.
Are all amps with rca in, low level inputs.
Old 09-25-2004, 05:02 PM   #5
ppgt94's Avatar
My Photos: (0)
Yes. Sound cards output low level.
Old 09-26-2004, 10:14 PM   #6
Nic
Nic's Avatar
Vehicle: 1993 TX3 Laser
My Photos: (0)
get a better amp
Signature: [==||========] 20% complete
Nic is offline   Reply With Quote
Old 09-26-2004, 10:18 PM   #7
darkhalo's Avatar
Vehicle: 2000 Honda S2000
My Photos: (0)
hrmm im using a 400watt audiobahn amp just for my two door component speakers. 200watts each @ 1ohm / 100watt each @2ohm
Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
S2000 Carputer
darkhalo is offline   Reply With Quote
Old 09-26-2004, 10:23 PM   #8
ppgt94's Avatar
My Photos: (0)
200 watts RMS? You're really running the speakers @1 ohm? Damn. I'm running 50x4 RMS to four MB Quart components and they are pretty damn load. I guess it's all about tastes but that car is tiny.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
car battery Slurpee General Hardware Discussion 35 09-08-2007 05:30 PM
HOW TO: Get sound from PC to Car Stereo / Amp ppgt94 The FAQ Emporium 147 05-31-2005 04:20 PM
I need to some basic information about amps Bust_A_Cap Car Audio 21 08-01-2004 09:31 PM
alright, sound distortion from over boosting. ares General Hardware Discussion 1 03-14-2004 12:04 AM
Help, amp trouble naevity General Hardware Discussion 9 01-14-2004 12:22 AM
Sponsored Links
Ad Management by RedTyger
