Old 10-11-2004, 06:13 PM   #1
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
What's up with my BRAND NEW speakers??
OK.. I replaced my rear speakers in my truck with Infinity Kappa 693.5i 6x9" 3 way speakers. They sounded great with my stock head unit and even better when I got my new head unit (25 X 4 RMS). When I turned it up to a certain volume it sounded like they were blown.. I don't turn the bass up and they weren't even hitting hard. I ended up sending them back and getting another brand new pair. I then got a set of Infinity Kappa 572.5CF 5x7" 6x8" 2 way speakers to replace my stock fronts.. I'm not experiencing this "sound" with all 4 speakers. I know there is no way they are blown because Infinity makes high quality stuff and I don't think my luck is that bad. They sound fine at low to mid volume but when I really want to jam I start to hear the sound (like popping hissing... hard to explain).
Anyone have any ideas of what can be wrong?
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 10-11-2004, 07:25 PM   #2
nirvanades's Avatar
nirvanades is on a distinguished road
are the speakers hooked up to your head unit? or an amp? You said you got a new pair - are they working fine? and now the fronts are the problem?
2003 Chevy Tahoe Z71
STOLEN - M10000, 512MB, 60GB 2.5" HDD, 7" Custom mounted Lilliput, Morex 3688 Case, 90W PSU w/ ITPS, GPS & CD-RW/DVD. New parts ordered for the next generation!
nirvanades is offline   Reply With Quote
Old 10-11-2004, 07:28 PM   #3
sdashiki's Avatar
sdashiki is on a distinguished road
I bet u got LOUDNESS turned on.
Whether you do or not its worth knowing, if u dont got an AMP, yeah loud can make it sound a little more rich, but at the expense of all it doing is upping the gain on the waveform that goes thru the HU. SO it can clip without u knowing it really, and in time sounds like crap during certain freqs. My advice to anyone WITH LOUDNESS as a button or feature, DONT EVER TURN IT ON. Tweak yer damn EQ to make it sound that way. Loud is BS and is really only good for stock only, cuz they are made of paper 99% of the time anyway.
dont take a chance with 3rd party $$$ speeakrs.
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
sdashiki is offline   Reply With Quote
Old 10-11-2004, 07:28 PM   #4
brrman's Avatar
brrman is on a distinguished road
It's what is known as "clipping".
Your headunit is not pushing enough juice to sustain the high output you are demanding. You need an amp. These speakers are RMS 100W each - and you are trying to support them with 25W/channel. You run out of juice, man.
Basically the top of the sine wave is being clipped off so instead of a nice curved sound wave, you get one that begins the upcurve, but then goes flat, and then begins its downcurve.
Constant use hearing this will ruin your speakers, keep the volume down until you can get an amp that will push enough power to support the high volume.
Car: 2000 Audi A4 Avant 1.8t
Carputer 2.0: removed. Back to stock.
brrman is offline   Reply With Quote
Old 10-11-2004, 08:11 PM   #5
Raw Wave
tbird2340's Avatar
This forum is da bomb... Thanks for clearing it up.. That sucks that I have yet another expense now though.. I do have the "LOUD" feature turned on and it does seem to make them sound better but I will turn it off like you suggest. It happens with both LOUD on and OFF.. Just at high volumes! I do not have an amp yet. What is a good amp (reasonably priced) for powering these?
Thanks again!!
Old 10-11-2004, 08:17 PM   #6
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
http://www.crutchfield.com/S-pIAxMlz...10&I=108R7520A
or
http://www.crutchfield.com/S-RK8xITO...20&I=108R7540A
Maybe one of these if you wanna stay with Infinity.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 10-11-2004, 08:26 PM   #7
Raw Wave
tbird2340's Avatar
Ouch $199... Me no have that much loot...
So am I looking for something that is X Watts x 4?
And I haven't had a system for about 6 years... Do the speaker wires go directly to the amp or do the RCA's go from the amp to the head unit?
For reference:
Infinity Kappa 572.5cf
Recommended power range 2-100 watts RMS
Peak power handling 300 watts
Recommended power range 2-110 watts RMS
Peak power handling 330 watts
Old 10-11-2004, 08:41 PM   #8
Tidder's Avatar
I would say for something to sound decent, you need to find an amp that puts out between 110 to 200 watts per channel. It's a common misperception that you need to match outputs to speaker wattages. You want to go a little higher to get a good crisp sound.
That's my $0.02 anyway.
Tidder
Try RevFE
Best Quote EVER!!
Old 10-11-2004, 11:06 PM   #9
timothy0605 is on a distinguished road
if one of the speakers are out phase it can cancel out lots of sound and make them sound like crap.
make sure all the positives and negatives are correct on the hu/amp and speakers.
timothy0605 is offline   Reply With Quote
Old 10-11-2004, 11:15 PM   #10
Naamanf's Avatar
Naamanf is on a distinguished road
[QUOTE=Tidder]I would say for something to sound decent, you need to find an amp that puts out between 110 to 200 watts per channel. It's a common misperception that you need to match outputs to speaker wattages. You want to go a little higher to get a good crisp sound.
That's my $0.02 anyway.[/QUOTE
You really don't need that much power. A good amp that puts out a true 50-75 watts would work just fine. Just don't try to get any deep base from them. They are not a sub so don't expect them to sound like one.
2007 Tahoe
Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
My Install
Naamanf is offline   Reply With Quote
Old 10-12-2004, 12:22 AM   #11
brrman's Avatar
an amp at 50-100W/channel rms is fine for your speakers. Even a cheap one - you don't need anything monstrous or high end brand name. Hifonics makes a good amp in that range and at a good price.
http://cgi.ebay.com/ws/eBayISAPI.dll...724311982&rd=1
Old 10-12-2004, 09:28 AM   #12
Aksor's Avatar
Aksor is on a distinguished road
From personal experience I know that most head units start to clip pretty badly at 3/4 volume. I actually tested a few using a test CD and monitoring the output with a scope.
Each time the sine wave clips (flattens out) the speaker is actually receiving a constant voltage that turns the coil into a heater and blows your speaker.
Aksor is offline   Reply With Quote
Old 10-12-2004, 09:31 AM   #13
Raw Wave
tbird2340's Avatar
So I should be getting a 4 channel amp right?
And what about hooking it up?
Old 10-12-2004, 09:37 AM   #14
Raw Wave
tbird2340's Avatar
So they could be blown already?
Old 10-12-2004, 09:59 AM   #15
Snootch's Avatar
Snootch is on a distinguished road
You only need a 4-channel amp if being able to fade front/rear is important. If not, you can run all 4 speakers with a stereo (2-channel) amplifier. About buying amps... I've bought 5 amps used off Ebay, and havent had a problem. I would stick to proven amps (old-school fosgate, PPI or Orion) and only buy from people with a high feedback rating. Here's some good 4 and 2 channel 50 watt per channel RMS amps Ive found for you:
http://cgi.ebay.com/ws/eBayISAPI.dll...725114918&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...725114956&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...725499724&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...725125537&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...724789381&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...725131200&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...725261411&rd=1
Good luck!
WORKLOG
Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
Webpage
Snootch is offline   Reply With Quote
Speakers setup and placement kingtut General Hardware Discussion 1 08-13-2007 03:37 PM
92 range rover speakers cutting out MAXXMODDER Car Audio 1 12-09-2005 05:40 PM
So I have decided to change out my factory speakers for something a little better. lawrence Car Audio 12 10-28-2004 07:44 PM
which speakers for my OLD bmw??? :confused: thorolf15 General Hardware Discussion 0 02-04-2004 09:22 AM
MBQuart 6.5'' component speakers for sale Mikesz Classified Archive 0 12-30-2002 10:05 AM
