10-18-2004, 02:07 PM
#1
Amp wont turn on, just keeps blinking, help!
Hey everyone,
I bought a used Clarion APX400.4 amplifier off a friend. I wired it up and when I try to power it up (turn on the stereo), the power LED just keeps blinking once every maybe 5 seconds and I hear a slight pop in the speakers. I tested the connections with a multimeter and they all appear fine. Any ideas what might be wrong and/or how I can fix it?
Thanks,
Chris
2004 Ford Mustang Mach 1
Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
Install Status: DONE
My XM FAQ
10-18-2004, 03:38 PM
#2
Is your ground ok? This is the most common problem...
051°55'30"N 04°34'31"E
10-18-2004, 04:49 PM
#3
Check your ground, fuses, and wires/connections. What size amp and what gauge wiring are you using?
10-18-2004, 06:43 PM
#4
Jesus Freak
Like he said... check all your connections. then double check, mine has done that a couple times and it was always mis wiring
10-18-2004, 06:53 PM
#5
my guess is check the ohm load.
Chris
Car= Dodge Neon ACR.
PC=Cappuccino GX1 Mini-Book - 800MHz, 256MB ,5GB, CD, XP payed $230
Screen=8" Lilliput XGA T/S payed $360
ITPS payed $46
DVD Drive payed $43
Ebay GPS Mouse + Software payed $52
10-18-2004, 10:47 PM
#6
My first guess would be the remote wire. Make sure that it has a good connection. I went through hell with one of my amps because of a single remote wire.
Quick! To the Popemobile!
10-19-2004, 12:33 AM
#7
i've checked all the connections, they are fine. i thought it was the ohm load too, doesn't seem to be. if i disconnect all the speaker wire and try to power it on, i get the same thing. the fuse keeps popping, so i just jimmy rigged a bypass and it still doesn't power on. just keeps blinking. god damnit. i think its fried
My XM FAQ
10-19-2004, 01:52 AM
#8
If you bypass the fuse then that chance is big yea
10-19-2004, 10:47 AM
#9
i bypassed it after everything else failed
My XM FAQ
10-19-2004, 10:55 AM
#10
Which fuse is popping? The amp fuse?
10-19-2004, 11:01 AM
#11
Another question: Are you using RCA inputs?
10-19-2004, 12:28 PM
#12
the amp fuse is popping, i'm using rca inputs which are coming from my sb audigy nx sound card
My XM FAQ
10-19-2004, 01:07 PM
#13
If you're blowing fuses whenever you turn on the amp, then its toast. Those should only blow when you're drawing too much amperage (IE, you've got it turned up too loud). Any other time they blow, its cause you've got a malfunction. Shorting it out to make it turn on is a seriously bad ******* idea. You could be dead shorting your battery, leads to dead batteries and melted insulation on your wires. No insulation means fire.
10-19-2004, 02:29 PM
#14
oh isn't that wonderful, sweet!
My XM FAQ
10-19-2004, 02:45 PM
#15
Adam is right. There is an internal short somewhere and the amp is probably blown. I would take it to a local electronics repair shop that does free estimates and see what it would cost to fix it if you can't send/take it back.
ATVMS.com
| Thread Tools |
| Display Modes |
Linear Mode
