I just got an Audiobahn A5100t 5.1 channel amp installed in my car. I am getting highly distorted signals from the computer to the speakers now. Before I was using a USB-to-RCA, but that only gave me 2 channels. I wanted to get a full surround sound system. This amp however is unlike any other amplifier that I have ever come in contact with. There are several problems that I am having.
1) The amp has a 2, 4, and 6 channel setting. If you set the amp on either 2 or 4 channels then you get sound to the center and sub when you are listening to winamp. If you switch to 6 channel though, it cuts those channels out. I know that it is getting sound to the channels because it plays when I do a speaker test in windows.
2) When the amp does play, the channels are extremely distorted even with the main and wave sounds at a low volume and the amplifier at a low gain. I am running 3 1/8" mini plug to rca adapters from my soundcard into the 6 channel inputs on the amp.
Here is what I have done to see if I can correct the 2 problems above:
1) ADS 4000 DAC. This should convert the digital coax output from the Audigy 2 into the 6 RCA channels.
I have a feeling that the sound is getting amplified 2 times and that is why its so distorted. If anyone has any suggestions then please let me know.
Max2fast4u@hotmail.com
