The MP3car.com Store
Thread Tools Display Modes
Old 10-22-2004, 08:01 PM   #1
My Photos: (0)
no name FM modulator....
I bought a no name FM modulator and i can barely hear anything/ ****ty. Is it because it's a no name? Thanks!
krazE is offline   Reply With Quote
Sponsored Links
Old 10-22-2004, 08:04 PM   #2
EBFoxbat's Avatar
Vehicle: 2004 GMC Canyon 4x4 Z71 Reg Cab
My Photos: (0)
no, it's because it sucks
'04 Canyon 4x4 pickup
[---PC on hold----working on external fiberglass "tool" box---]
EBFoxbat is offline   Reply With Quote
Old 10-22-2004, 08:10 PM   #3
blurp's Avatar
Vehicle: 2003 Chevy Impala LS
My Photos: (0)
But seriously, are you sure it is a modulator or is it a transmitter? Have you checked all of the obligatory things like replacing the cable, sound settings on PC, etc?
www.bradleyjacobs.com
There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
blurp is offline   Reply With Quote
Old 10-22-2004, 08:12 PM   #4
Raw Wave
TruckinMP3's CarPC Specs
TruckinMP3's Avatar
Vehicle: '02 suburban with quad captain seating
My Photos: (0)
Got what you paid for, return if you can. Learn from that mistake.
TruckinMP3
D201GLY2, DC-DC power, 14in LCD ;) 3.5 inch SATA
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 10-22-2004, 08:34 PM   #5
HummDinger's Avatar
Vehicle: 98 Ford
My Photos: (0)
Wink
I bought this FM transmitter and have it hooked up to a 12 volt supply from the molex connector. It works great. No noise, no static, crisp and clear. Also wireless... and only $35.00
ebay link
I have tried the USB line-X and got a lot of line noise as well as static. Plus only 6 channel selections, no good hear. I have also tried an inline modulator, very bad choice. Lots of line noise, alternatore noise and poor sound quality. Ditch the modulator and get a transmitter like the one above, it works great.
You can still have something if you have nothing
HummDinger is offline   Reply With Quote
Old 10-22-2004, 08:49 PM   #6
My Photos: (0)
The one I have right now is this: http://cgi.ebay.com/ws/eBayISAPI.dll...718518506&rd=1
I think I will look into the FM transmitter... thanks everyone!
Old 10-22-2004, 08:54 PM   #7
HummDinger's Avatar
Vehicle: 98 Ford
My Photos: (0)
That is the same one I was using, pretty funny actually I battled with the sound issues for about 1 year, then I gave up and tried something different and low and behold it works.
Old 10-23-2004, 08:18 AM   #8
blurp's Avatar
My Photos: (0)
You'll probably regret that. I used one at first, and it sounded great for about a month, then turned to crap. Most others on this forum who have used them expressed the same sentiment. I now use an audiovox modulator, and it's been sounding great for a year. Just be sure to ground everything PROPERLY. for what I mean on that.
Old 10-25-2004, 10:42 AM   #9
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
I just digging thru my factory HU yesterday and found a way in integrate "Aux input" that I think can sound much better than any "adapter" except the true aux input adapter. That is to tap into the Analogue audio signal from the CD part to amplifier. I will post the complete procedure when I get home.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 10-26-2004, 01:18 AM   #10
MySQL Error
MatrixPC's Avatar
My Photos: (0)
Ok here is what I did on a GM/AC/Delco made Radio on my Toyota Matrix (this radio is similar to most radio on GM cars/trucks)
- Trace the audio signal from the CD player to the amplifier board by using head phone. Cut the plug to expose bare wire or solder/tape 2 piece of wire (GROUND and LEFT or RIGHT) to the plug and use it to probe around.
I found 2 signal wire on a 6 pins connector (Black pin 1 is LEFT and white pin 3 is RIGHt pin 2 is GROUND).
I cut that 2 audio wires pin 1 and 3.
Solder a DPDT relay
The result is a mini stereo jack for aux in and a wire dangling out side to enable and disable aux input (driven the relay)
There is NO noise or engine whine when I use a discman to feed the audio. No computer setup in the Matrix yet so I don't know if there will be noise with the PC.
Sponsored Links
vB code is On
Trackbacks are Off
FM Transmitter vs. FM Modulator Uzi4U Newbie 7 02-18-2005 09:20 PM
Integrate mp3 player w/ Alpine FM modulator ? L0C0 General Hardware Discussion 0 03-04-2004 12:45 AM
FM Transmitter / FM Modulator owenjh General Hardware Discussion 8 12-30-2003 06:29 PM
FM Modulator... which one? justinham General Hardware Discussion 17 04-02-2002 11:56 AM
Which one is better? FM Transmiter or FM Modulator helloman General Hardware Discussion 6 03-12-2001 09:15 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
