Old 10-25-2004, 02:03 PM   #1
Matthew230 is on a distinguished road
Red Red Whine....
Everything installed and, but speakers are buzzing and whining, some of it is clearly related to when the hard drive working, and some of it is related to the engine revs.
The setup -
Micro Atx board 2.4 celeron, with onboard sound, the speaker line is connected with RCA's to the CD changer, where I have cut the left and right audio feed and attached female RCA's (I hope this is clear)
The car is powered via cigarette lighter. Opus 150w.
I have tried lots of different grounding points, nothing makes a difference. I have tried powering it direct from the battery, still no difference, I have tried grounding the case, and the opus chassis, still whining and buzzing.
It doesn't matter if the ignition is off or not, but if the PC is shut down then there is no noise.
I have tried plugging the headphone jack that goes into the PC into a portable CD player and everything is fine, no noise.
I have plugged external speakers into the PC and there is also noise on them.
Can anyone tell me what to try next, and likely causes given the symptons and test results above.
Many thanks,
Matt
Matthew230 is offline   Reply With Quote
Old 10-25-2004, 02:35 PM   #2
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Have you tried grounding your audio ground?
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 10-25-2004, 03:16 PM   #3
Apologies for my ignorance, but how do I do that ??
Thanks,
Matt
Old 10-25-2004, 03:29 PM   #4
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Try not to power the Opus via the cig lighter. Wire it directly to the battery and use the cig light wire for turn on the Opus (IGN).
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 10-25-2004, 04:16 PM   #5
Cigarette lighter is permanently on. So can't do that. Tried hardwiring it to the battery and there was no improvement.
Do you know how to ground the audio?
Thanks,
Matt
Old 10-25-2004, 04:23 PM   #6
Clover
Grayscale's Avatar
Grayscale is on a distinguished road
try grounding the motherboard to the case of the opus?
CarPC install is starting to come along again...
Grayscale is offline   Reply With Quote
Old 10-25-2004, 04:32 PM   #7
Surely the motherboard should already be grounded to the case which is grounded to the opus which I tried grounding independently to no avail.
Can anyone tell me how to ground the audio, or offer any other suggestions ??
Thanks,
Matthew
Old 10-25-2004, 08:10 PM   #8
Tidder's Avatar
You ground the audio by splicing into your audio wire, and using it's ground to connect to chassy ground. Fixed some major audio whining in my car.
Tidder
Try RevFE
Best Quote EVER!!
Old 10-25-2004, 10:41 PM   #9
Huflungdung5342's Avatar
Huflungdung5342 is on a distinguished road
ground it by exposing a section of the chassis' metal, sand off some of the paint, and attach the ground wire to it
Huflungdung5342 is offline   Reply With Quote
Old 10-25-2004, 11:07 PM   #10
coachreed's Avatar
coachreed is on a distinguished road
You should have your grounds for amps and source (headunit and/or computer) grounded to the SAME point on the vehicle chassis... if that means you have to run an extra ground wire from the front to the rear of the vehicle, you should do it... just keeps from having ground-loop problems where you will most likely pick up noise due to a potential voltage difference. If that made ANY sense.
Later!
Coach... aka Randy! (I often forget who I really am!) ;)
***Too many pieces and parts to list... maybe someday I'll show'm to ya!***
coachreed is offline   Reply With Quote
Old 10-25-2004, 11:18 PM   #11
Bowel movement
jjh221's Avatar
jjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud of
I had the same problem . I had my lilliput powered by my psu, and i found when i turned off the lilliput most of the idle noise went away, but still having the harddrive and engine reve noise. So what i did next was solder the lillput to the cig lighter. Work, well for that much. I still had the harddrive noise and engine rev noise. So what i did next was ground the mobo to the same ground, on the cig lighter, as the lilliput. My problem was solved.
jjh221 is offline   Reply With Quote
Old 10-26-2004, 08:29 AM   #12
Ok,
I'm going to ground everything to one point, and see what that fixes.
Though I'm not clear on how to ground a motherboard.
Can anyone help with this ?
Cheers,
Matt
Old 10-26-2004, 08:33 AM   #13
EBFoxbat's Avatar
EBFoxbat is on a distinguished road
The ATX power (from the OPUS) should take care of your motherboard ground.
'04 Canyon 4x4 pickup
[---PC on hold----working on external fiberglass "tool" box---]
EBFoxbat is offline   Reply With Quote
Old 10-26-2004, 09:11 AM   #14
I'm still a little unclear about grounding audio.
I have a headphone jack line out that goes into RCA left and right.
Am i cutting into each of these wires and making a ground, or am I using the shield wire aroud them and grounding that ??
Cheers,
Matt
Old 10-26-2004, 11:01 AM   #15
Bowel movement
jjh221's Avatar
My mobo is not in a case, but screwed to some plexy glass. Your ground on the mobo is where the screws go to hold it to what ever it is attached to. If ya notice the holes are circled in metal or whatever.
If your audio is to your head unit i would think that that is already grouned.
what does this tell me? (regarding whine in speakers) nappyjim Car Audio 15 10-20-2004 09:49 AM
Do any keyboards come with RED backlighting? imprezive one Input Devices 14 10-08-2004 09:00 AM
Why MMI Red 800X600 no worky? STI_FFY FrodoPlayer 5 06-27-2004 09:38 AM
Engine whine mobileh1 Software & Software Development 20 05-26-2004 07:28 PM
Headunits with red lights? none General MP3Car Discussion 7 03-28-2004 07:32 AM
