Old 10-27-2004, 10:14 PM   #1
Murphy3603 is on a distinguished road
cant get power to amp
i ran the wire through my firewall and everything is fine.. and then i hook my ground and remote wire up.. then i go to go my power wire and i hook it up fine i go to check if i have power to the amp... NO.. i then redid the ground remote and power wires to my amp check it again NOTHING.. then i think maybe the power light is burnt out.. so i hook up my speaker wire adn then hook it up to my sub.. NOTHING.. got anything for me guys..?
Murphy3603 is offline   Reply With Quote
Old 10-27-2004, 10:26 PM   #2
migel628's Avatar
migel628 is on a distinguished road
Is your grounding point a straight metal contact w/ no paint in the way? That's a good place to start. Is the power wire secure on the positive battery terminal? Have you checked to make sure the power wire is actually transferring electricity w/ a DMM? Just a few ideas too look into...
"I'm a dick!"
"I must seek knowledge and it's bastard son truth" - The State
migel628 is offline   Reply With Quote
Old 10-27-2004, 10:40 PM   #3
IamMBS is on a distinguished road
Are you sure you have 12volts on your remote wire? I know a few radios (not many) have the remote wire fused, check that. Or better yet, jump the remote input to your main power wire and see if it turns on.
IamMBS is offline   Reply With Quote
Old 10-27-2004, 11:02 PM   #4
Or better yet, jump the remote input to your main power wire and see if it turns on.[/QUOTE]
is that safe to do.. or will something blow
Old 10-27-2004, 11:14 PM   #5
fantomas's Avatar
fantomas is on a distinguished road
use a different ground. i was helping a friend install his amp...they couldnt figure out whats wrong, so i came over with my DMM and measured 3 volts. he grounded it to the back seat which really has no good contact to the car chassis. just found a better ground and everything worked perfectly.
rebuilding carpc... kinda..
fantomas is offline   Reply With Quote
Old 10-27-2004, 11:17 PM   #6
fantomas's Avatar
something will blow if you connect the remote wire to the + contact on the amp. you'll be fine though if you connect the power wire to both the + and REM contact on the amp though
Old 10-28-2004, 03:43 AM   #7
Matthew230 is on a distinguished road
Get a mulitmeter, it will save your hours of testing different problems.
Matthew230 is offline   Reply With Quote
PC Power Supply and Car Amp GezusK Car Audio 6 05-10-2006 01:31 AM
12v Power Supply at MP3Car.com store mykolJay Power Supplies 6 02-02-2006 10:17 PM
Sound not very loud have i bought the wrong amp rickyaswell Car Audio 7 09-26-2004 11:23 PM
getting an odd motherboard to power on karmann Power Supplies 13 11-28-2001 06:27 PM
HELP!! Power Supply wont supply power Saab General Hardware Discussion 3 08-28-2000 10:33 AM
