Old 10-30-2004, 01:10 PM   #1
legend5761 is on a distinguished road
Sound Card on PCI rather than external
Hey guys, is it alright to get a internal sound card instead of an external? I see alot of people get the external I was wondering why? Thanks.
legend5761 is offline   Reply With Quote
Old 10-30-2004, 10:08 PM   #2
mushin's Avatar
mushin is on a distinguished road
Reasons to go external may be space (a card perpendicular to your MB can be quite cumbersome), lack of slots (many people use mini-ITX boards with only one PCI slot) or securing it (PCI cards in some custom enclosures might come loose from vibration). If these aren't issues for you, then internal should be fine.
mushin is offline   Reply With Quote
Old 10-30-2004, 10:13 PM   #3
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Go with what fits your: case, budget, quality needs.
As Mushin said the reasons are individual.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 10-31-2004, 12:36 AM   #4
starfox's Avatar
starfox
External is easier. I have a SB Live in my car computer. Without it, the computer would be about 5cm high. With the SB Live, it's about 12cm, which makes it more difficult to fit in tight spaces.
Unless you need some special features that aren't available with onboard sound, or with a USB sound adapter, using a PCI card is a bit of a hassle.
starfox is offline   Reply With Quote
Old 11-01-2004, 09:07 AM   #5
cold_fusion is on a distinguished road
Hey,
I have read tho that external USB soundcards, esp the cheaper ones such as Trust 510, creative soundblaster live usb & mp3+ usb, resample the analogue signal to 48khz, so all audio that is encoded @ least than 48khz (i.e CDs (44.1khz), and pretty much all mp3s) has is resampled by the software drivers up to 48khz, this leads to a decrease in audio quality, which i'm sure is the last thing you want.
I can't say if you can hear the difference, im sure some people can tell, but i don't have an external card to test this out. If your amp is digital then you're ok, as they send the spdif signal @ 44.1 & 48khz.
I was gonna consider an external usb card myself, but after reading this Im gonna stick with the audigy.
Dunno if this is true with the expensive audigy 2 external range, i only looked up the cheaper ones.
Something to research methinks!
Gaz
cold_fusion is offline   Reply With Quote
Old 11-01-2004, 11:46 AM   #6
lummox is on a distinguished road
FYI audigy 2 NX is 96kHz and has optical in & out and spdif in & out, as well as mic in and line in
lummox is offline   Reply With Quote
Old 11-01-2004, 12:03 PM   #7
starfox's Avatar
starfox
Yes some of them do. It depends on the chipset and what the driver's designed to do. iirc some AC97 Codec ICs (eg. Sigmatel STAC) will only output at 48khz and nothing else (cost cutting i guess), though the resampling is done digitally so it's hard to notice unless you look out for it.
I thought some other PCI cards do this as well? I think most of the Emu10k series cards do this (SB Live, Audigy), as they output 48khz AC97 to a AC97 Codec for DAC on some of the channels... Everything's upsampled.. That's why you get plugins for Winamp like this.
Old 11-01-2004, 05:07 PM   #8
yep, i stand corrected, seems like the audigy isn't the best example for a great music soundcard...
See here half way down in the FAQ
I know my soundcard for the car computer! envy24ht based
of course if you have the cash u want one of these...
EMU Soundcards
Old 11-01-2004, 07:05 PM   #9
edikp is on a distinguished road
Do you know if Audigy 2 NX auto power on (as windows loads or mobo starts up, etc)?
EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
edikp is offline   Reply With Quote
Good PCI Video Card for 800x480 veetid Software & Software Development 11 06-14-2004 01:48 PM
Surround Sound: Internal preamp or external preamp? GnatGoSplat Newbie 0 04-04-2004 02:15 PM
got sound? masch Newbie 20 11-17-2003 10:01 AM
setting sound card volume cheesyhoward Software & Software Development 8 10-17-2003 05:11 PM
adding another sound card?? moahdib General Hardware Discussion 7 04-25-2002 07:57 AM
