Old 11-04-2004, 10:42 AM   #1
Murphy3603 is on a distinguished road
what type of amp should i get
i have a 12' jl audio w3 with a bandpass box adn im not sure what type of amp and wattage im looking for..
Murphy3603 is offline   Reply With Quote
Old 11-04-2004, 10:53 AM   #2
IntellaWorks's Avatar
IntellaWorks is on a distinguished road
It all depends on the type of bass you want really. If your looking for "I can hear you 5 blocks away" then get anything from 500-800w If your looking for good all around bass including surround sound, then get something around 150-300w
I used to have a jl 10" in a single cab truck being powered by 150W 1ch. amp and it was fine for me. Keep in mind that my setup was different because it wasnt in a trunk the speaker was in the cab with me making it louder naturally. I also had a single cab small truck with not a lot of space.. this also made a difference because I was sitting on the speaker, so to me it was pretty loud.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 11-04-2004, 10:58 AM   #3
i want something good but i dont want to blow my speakers
Old 11-04-2004, 05:03 PM   #4
LeoTheHamster's Avatar
LeoTheHamster is on a distinguished road
What voice coil is the sub? D2, D4 or D6?
Leo
http://www.talkaudio.co.uk
Quote:
A million people can't be wrong, right?
Well... unless they're all from the red states...
LeoTheHamster is offline   Reply With Quote
Old 11-04-2004, 06:52 PM   #5
D2 voice coil
Old 11-04-2004, 07:18 PM   #6
Altimat's Avatar
Altimat is on a distinguished road
I'd get this one:
http://www.ikesound.com/product-product_id/2109
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
Altimat is offline   Reply With Quote
Old 11-04-2004, 07:19 PM   #7
voidunknown is on a distinguished road
Actually his JL W3 will only hold 300 Watts RMS. I recomend a Elemental Designs NINE.2 amp for your JL W3. It will feed 400 Watts RMS @ 4ohms, just be careful setting the gains and you will be fine. More info on the amp here:
http://www.edesignaudio.com/edamps.htm
Good luck, let me know if you need anything else.
voidunknown is offline   Reply With Quote
Old 11-04-2004, 07:21 PM   #8
Quote: Originally Posted by Altimat
He can't get that one. His woofer is Dual 2 ohm, which means he can hook it up at either 1ohm or 4ohm to the amp. You need something that puts out 300-400 Wats at 1ohm OR 300-400 Watts at 4ohms. That amp is not 1 Ohm stable and 250 watts might not do his bandpass box justice.
Old 11-04-2004, 08:59 PM   #9
i have a crossfire 600 watt amp.. and i cant get it to work ive tried everything so im tryin to get a new amp or soemthign so i can get my damn system hooked up
Old 11-04-2004, 09:16 PM   #10
Altimat's Avatar
Ohh I didn't realize that. Assumed it was 2 Ohm. The D6 threw me! I had that same problem with my ED12A and ended up using two MRD-M300 Alpine V12 Amps since I had one already - one on each voice coil. Works great!
Old 11-05-2004, 12:51 AM   #11
Yea, but I don't think he is experienced enough to hook up one amp to each voice coil
ED12A was a great woofer.
Old 11-05-2004, 01:06 AM   #12
Nic
Nic's Avatar
Nic is on a distinguished road
why dont u look at the specs on the JL website? it reccomends what kind of wattage you should put into the sub
Signature: [==||========] 20% complete
Nic is offline   Reply With Quote
Old 11-05-2004, 01:10 AM   #13
I already stated in an earlier post that 300 Watts RMS was the Max recomended wattage. If done correctly, 400 would be fine.
Old 11-05-2004, 02:43 AM   #14
choyak's Avatar
choyak is on a distinguished road
I had that one and it was rubbish. It was driving dual 10" MTX thunder 4500 (I think) when the sound stopped and the smoke chugged out of the amp . I tested it and 3 of the MOSFETS 'wired out' (fried). After that, I put in a Crossfire and it was good ever since. (I have since sold the car and have NOTHING other than the stock system)
Carputer currently 'ghettoed' into car!!!
EPIA MII-12000
Ampie Case with rigged extra USB
Hitachi 60GB
Holux GPS mouse with iGuidance 2.0
Lilliput 7" touchscreen
Netgear WG121 USB WiFi
Carnetix P1260
choyak is offline   Reply With Quote
Old 11-05-2004, 03:20 AM   #15
Nic
Nic's Avatar
ahh obviously i didnt read thoroughly enough, so i assume the driver is a W3v2 then?
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 03:41 AM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 01:25 AM
Sound not very loud have i bought the wrong amp rickyaswell Car Audio 7 09-26-2004 11:23 PM
People with NO HeadUnit, Recommand AMP!! camsgs3 Newbie 30 07-26-2004 07:38 PM
EPIA M9000 connection to car amp wi77iam General Hardware Discussion 2 08-08-2003 02:37 PM
