Old 11-08-2004, 03:44 PM   #1
Sway's Avatar
lincoln continental JBL amplifier?
I have a 1989 lincoln continental and was looking for the specs for the stock JBL amplifier and cant anything about it. all it says on the amp is "ford JBL e9of-18b849-ac433m" please help
thanks
Sway is offline   Reply With Quote
Old 11-08-2004, 03:49 PM   #2
fuctup's Avatar
no idea but i by-passed mine in my old lincoln
fuctup is offline   Reply With Quote
Old 11-08-2004, 04:21 PM   #3
Sway's Avatar
i need to know the wattage because im going to get a very cheap sub and try to hook it up to the amp, if anyone has any tips on how to do that it would be helpful, because theres no sub hook ups so i was going to wire it to my speakers .
thanks
Old 11-08-2004, 09:43 PM   #4
Best bet is going to be an aftermarket amplifier to power a sub. Those factory amps just don't push enough juice to power a sub, they weren't designed for it. Plus if you wanted to do that you'd need two subs since the amplifiers are not capable of running mixed mono. Wattage is probably somewhere in the neighborhood of 20-50W (I'm guessing), you could try www.alldatadiy.com for more detailed specs. Might also be in the owners manual.
Jailer is offline   Reply With Quote
1982 Lincoln Continental Carputer install MeanGT Show off your project 31 05-29-2004 02:18 PM
Need some help with sending audio to stock amp orangewhip General Hardware Discussion 12 09-04-2003 01:21 PM
SoudBlaster PCI128 Do I need amplifier Eddy25 General Hardware Discussion 6 10-07-2002 09:57 PM
88' Lincoln lstrunk General MP3Car Discussion 8 07-11-2001 02:42 PM
can I use an amplifier for rca input?? sheriff General Hardware Discussion 1 03-23-2001 08:03 AM
