Old 11-28-2004, 02:33 AM   #1
SwapMeet is on a distinguished road
Lost 12V power after rewire. Help!
I've seem to have lost my 12V power going to my headunit sometime during a rewiring project.
Background:
2000 Ford Mustang, aftermarket Kenwood head unit installed by Best Buy.
What I did:
I wanted to tap the 12V wire to power a mobile monitor. However, sometime during the process I lost power from the factory harness. Now I can't power either the monitor or the head unit, together or separately. I've checked voltages with a multimeter.
What I've done since:
I've checked all the fuses in the passenger compartment. I looked up my fuse box diagram and swapped out any fuses that were associated with the radio.
Any ideas on what happened?
SwapMeet is offline   Reply With Quote
Old 11-28-2004, 04:53 AM   #2
Fox_Mulder's Avatar
Fox_Mulder is on a distinguished road
Fuses in the engine compartment?
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
Fox_Mulder is offline   Reply With Quote
Old 11-28-2004, 04:55 AM   #3
FLA
gospeed.racer's Avatar
gospeed.racer is on a distinguished road
Check all the butt connectors and see if a wire pulled out? I know how some of those "pro's" install, and it makes me sick. If no fuses are blown, there is a good chance something simply pulled out. Look in the areas that the installer would have messed with.
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
gospeed.racer is offline   Reply With Quote
Old 11-28-2004, 12:09 PM   #4
Checked the butt connectors myself. In fact, I redid the butt connectors on the 12V and the ground because theirs was sloppy. At least theirs worked.
Old 11-28-2004, 12:11 PM   #5
I'll take a quick peek, but I'm not sure if there are any fuses there that are connected to the radio.
Old 11-28-2004, 04:55 PM   #6
John M's Avatar
John M is on a distinguished road
Are you missing constant 12v or switched 12v? If it's constant, you probably blew the dome light fuse.
2005 Subaru Legacy GT
Status: 40% - starting install
• AMD Sempron 3100, Biostar K8NHA PRO mobo, 512 meg DDR, WD 200 gig SATA, Opus 150, Xenarc
• JBL GTi 6.5 fr, JBL 5.25 rr, (3) JBL 75x2 & 1 1200x1 amps, PA MOFO 12 sub
John M is offline   Reply With Quote
Old 11-29-2004, 12:19 PM   #7
I went to Wal-Mart and picked up a fuse checker. Turns out one of my fuses in the engine compartment was bad, I just couldn't see it at first. Thanks for all the help.
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 10:31 PM
Car power supply (battery charger) from old pc supply stimps Power Supplies 8 08-24-2004 08:59 AM
Power Question/Setup Question, minibook pc seamonkey420 Newbie 4 05-17-2004 10:47 PM
USB2 hub with 12V power supply. blaster General Hardware Discussion 20 01-27-2004 06:29 PM
12v dc-dc atx power supply plasmadis General Hardware Discussion 1 06-28-2000 05:51 AM
