how best to power my amp?
Hey guys, well you all been great upto now, maybe you can help me one more time,
im installing a pc in an MR2, This has a stock amp, it has no standard inputs into it, so i cannot mess with the wiring on the staock amp, and its in a really awkward place.
I have found out how to give it power, on the harness i bought you get 4x phonon cables, if i push a signal through those and connect the red cable on the harness that should go through a HU to the blue amp remote, the amp kick in and hey presto we have wicked sound. - but it killed my battery - drained it dead!
now..... i need to know where to cable from to enable me to get the same effect but the connection is established when either the engine is started or when i turn the key.
Do i wire from the ignition barrell? as the wire on the harness is a permmanent live ( or seems to be) although it says IGN 12+v on the cable.
My question --- i need to wire the remote amp cable on the harness to where ( that wont kill my battery ) not keen on using a switch as i will definately forget to switch it off.
Please help
cheers
