01-03-2005, 12:34 AM
#1
Vehicle: 2001 Ford Expedition
amplifier remote output question
i was wondering if it is safe to connect the remote output from my amplifier to my computer power supply (yellow wire)? i would like to turn on my amplifier same time with my computer.thank you
01-03-2005, 12:44 AM
#2
Vehicle: 2004 Infiniti G35 6mt Coupe
by yellow wire, do you mean of these three wires, power, gnd, and "ign/acc" or whatever? Like what the opus takes?
and by "remote output" do you mean the signal that tells the amp to turn on or off?
If the answer to both of those questions is yes, then the answer to your question is yes, it's safe. The remote signal on the amp uses VERY little current. Low enough that it's safe to ignore it for this purpose.
01-03-2005, 01:02 AM
#3
yes remote output from my amplifier to yellow wire from power supply molex to turn on my amplifier,thank you wizawuza
01-03-2005, 01:33 AM
#4
My Village Called
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
I think you'll get a "pop" from the speakers if you do that.
01-03-2005, 11:07 AM
#5
really? I don't, and mine is like this. My amp *might* have some sort of protection.
You know what... I think it does, because if I already have the computer running, and music playing on it, but the amp is off, and then I later put the remote lead on, the amp very slowly increases the volume from zero to whatever it's set volume is.
Maybe that's why I haven't had a problem. If this does cause a problem with other amps, then I apologize for giving incorrect advise.
01-03-2005, 11:20 AM
#6
Vehicle: 02 WRX
nooo use a relay. if you connect the yellow wire directly to the remote turn on you'll be connecting 2 different 12 v circuits. well..more like a 12 volt circuit and a 12-14.5 volt circuit. connect it with a relay and you'll be fine.
rebuilding carpc... kinda..
01-03-2005, 11:26 AM
#7
wha?
what does it matter if you connect the 12V INPUT of two circuits?
Neither the amp nor the opus/whatever PSU does absolutely anything to affect the voltage on the remote/yellow wire.
Fanning out like this will not make a difference. And even if you did use a relay and all that, where's the 12V that goes into the relay come from? The same battery/alternator, which means that it's still all connected anyways. Sure now there are difference fuse/wire paths, so this would be helpful if either of those two wires needed high current, but they don't.
01-03-2005, 11:28 AM
#8
Vehicle: 2000 VX Vectra SXi
Yeah, I use a relay for my set up, the signal from the stereo goes to the coil and a second supply gets fed to the Amp / PC (ITPS). Will also be using it for trick lighting in the boot so it's worth doing for the upgrade-ability alone.
2000 Vauxhall Vectra SXi
EPIA M12000 / 256MB RAM
PW-120 + ITPS
Slot Loading CDRW/DVD
30GB 2.5in HD
Lilliput 7" VGA + Touchscreen
GPS Nav
Installation progress {+++++++} (Installed! :) )
01-03-2005, 11:29 AM
#9
Vehicle: 02 WRX
hmn...well i've never actually tried it, but i would figure that there would be some sort of ground loop or something. i'm probably wrong.
01-05-2005, 12:03 PM
#10
Vehicle: 2004 Hyundai Accent
I tried the relay bit, doesn't work (Didn't make any sense anyway) Need some type of delay, so the sound card turns on before the amp.
Anyhow, I have a on/off cruise switch on my steering wheel, I tapped the remote wire (from the amp) into the cruise relay output terminal. Works great, I wait for pc to come on, then I turn the cruise control on. (cruise still works fine too.)
When I shut the car off, it shuts of the amp also, no noise when the pc shuts off or hybernates.
Now faith is being sure of what we hope for and certain of what we do not see.
01-05-2005, 12:10 PM
#11
good stuff... yeah I guess mine works fine cause it kinda has a built in delay on the amp.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
