Old 01-31-2005, 11:42 AM   #1
Ctrl_phreak is on a distinguished road
RCA dynamic voltage range...?
i am having difficulty choosing a set of amps for my vehicle. Lacking a multi meeter i have no idea how much voltge is output from a computer's soundcard on each channel. Does anyone know the range? does teh sound card effect it?
Gigabyte nForce2pro (rev. 2) onboard sound
amps in question take a range of 150mv to 4v
or 120mv to 5v
depending on set i get
Any idea guys? Im tryin to prevent clipping and burining out things if i can.
Thx alot
Ctrl_phreak is offline   Reply With Quote
Old 02-01-2005, 10:23 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
from my testing - the ONBOARD sound puts out only .5v
you will want to boost that voltage to an acceptable level. I used an Arc Audio PEQ-7 which is an eq, it boosted my voltage to 9v. Doing so will give you a much cleaner sound. You also won't have to worry with trying to find an amp that matches your output voltage of your sound card.
In general, i think that you are looking at this with too technical of a mind...lol
just pick an amp that you like, and get something like an eq or other that will boost your voltage level to an acceptable level...
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
How do voltage regulators track when the input voltage drops too low? Arathranar Power Supplies 7 01-14-2005 11:56 AM
Bug Reports 1.09 frodobaggins FrodoPlayer 279 10-22-2004 11:24 PM
What Gauge wires do I use? Showmehow Newbie 25 07-25-2004 11:41 AM
Voltage issues with ITPS? mcrussell Power Supplies 1 06-06-2004 11:48 PM
DC-DC psu and high capacity HDD GrahamS General Hardware Discussion 46 12-19-1999 06:44 PM
