Old 02-03-2005, 07:27 AM   #1
Poom is on a distinguished road
Problem with FM Modulator!
Hi Guys,
I have just bought an FM Modulator while I save up for a decent amp and I have wired this in finally and the sound works a treat! The only thing is, when I use the modulator the screen goes distorted! Could this be inteference from the 2 sound cables (white and red) to the yellow video cable which goes into the screen?
If it is, how can I prevent this?
Poom
Poom is offline   Reply With Quote
Old 02-03-2005, 10:28 AM   #2
Coeus is on a distinguished road
Not sure on that, but I am going to be hooking up a similar situation tonight or this weekend. I'll let you know how mine goes.
Coeus is offline   Reply With Quote
Old 02-03-2005, 04:22 PM   #3
It seems to work on some programs and games but not others!
Even when the FM modulator is not powered but the Audio cables are plugged into this it still happens but as soon as they are unplugged it works again!
Does anybody have any ideas?
Old 02-03-2005, 07:05 PM   #4
CornToeGoblin's Avatar
CornToeGoblin is on a distinguished road
Are the wires really close to the monitor? I'm thinking you might have some kind of magnetic field going through those wires. Try with a different type of wire. Other than that i can't think of anything else.
Try to post a picture of how it gets distorted.
2008 Civic... Sound system... then carputer install...
WORK IN PROGRESS
If you look at my avatar closely, you can see a chick with two big knockers....
CornToeGoblin is offline   Reply With Quote
Old 02-03-2005, 07:25 PM   #5
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Check all your grounding wires.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 02-04-2005, 04:01 AM   #6
I just checked the ground wire for the FM modulator and I cut it so Ican get a decent earth on the chassis somewhere and the modulator still appears to work when there is no ground wire connected?
Everything else (Inverter and screen) is using the same earth as I am using a 3 way cigerette lighter adapter! Would this make a different if I earthed this to the chassis also?
Old 02-04-2005, 09:02 AM   #7
Just tried this with a DVD player (house type) and it worked fine! So I put it down to the Xbox!
Old 02-04-2005, 09:15 AM   #8
david_liz's Avatar
david_liz
What modulator do you have? I'm looking for one, and don't know exactly which to buy. Thanks!
david_liz is offline   Reply With Quote
Old 02-04-2005, 10:01 AM   #9
K - E - X is on a distinguished road
david_liz, i've tried a couble of FM modulators with varius problems... finally end up with this one http://www.cartft.com/carpc/catalog/il/393
Works great for me.
- CarPC: Lilliput 7" Touchscreen, VIA EPIA M10000, 512 MB, 40 GB HDD
- Install: 90%
K - E - X is offline   Reply With Quote
Old 02-04-2005, 10:25 AM   #10
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
That's not just a modulator, that's a transmitter!
The distortions seem like a ground-issue, as Truckinmp3 said, check that.
The modulator will work without a ground-wire as it gets the ground over the soundwires, which creates a ground-loop, not good.
JC-S60 is offline   Reply With Quote
Old 02-04-2005, 10:30 AM   #11
EBFoxbat's Avatar
EBFoxbat is on a distinguished road
Spiral copper wire around your AV cables and then ground the copper wire. This should cut interference. It's gross but would work.
You could get rid of the modulator all together.
'04 Canyon 4x4 pickup
[---PC on hold----working on external fiberglass "tool" box---]
EBFoxbat is offline   Reply With Quote
Old 02-04-2005, 10:51 AM   #12
I just flashed the BIOS on the xbox and it works fine :S
Thanks for your help guys!
Tape adapter or FM modulator? kefka_killer Car Audio 15 08-26-2004 02:03 AM
FS : LineX USB FM Modulator Stavros Classified Archive 2 02-06-2003 01:05 PM
FM Modulator Antenna Hookup Question grandamp3 General Hardware Discussion 5 01-21-2003 11:44 PM
fm modulator problems cruzc_99 General MP3Car Discussion 2 01-14-2002 09:29 AM
Which one is better? FM Transmiter or FM Modulator helloman General Hardware Discussion 6 03-12-2001 10:15 AM
