Exactly, I was thinking I was going to end up having to run stereo audio all the time by splitting the front outputs. I just think it would be dumb to have surround sound, then switch to xm and bam front channel only. I want it one way or the other.
I'm looking to run the Extigy off of my powersupply. Do you have any idea if the M1-ATX would supply enough power on +12V that I would be ok running an EPIA M10000 and an extigy off of it? I'm not sure what the amp usage is for the EPIA or the Extigy. It says in the specs though that the M1-ATX will supply 2 amps on +12V.
I plan on running frodoplayer, but thanks for the tip, I will use a dedicated usb port. I plan on using serial for XM and GPS anyways which just leaves the touchscreen(for now).
Hey, have you tried using the remote to control frodoplayer to skip songs or anything like that? I'd be happy with just volume up/down and mute, but it'd be nice if i could do something useful with the rest of my steering wheel buttons as well.
Quote: Originally Posted by rjoek
Yeah, I tested the Audigy NX and found out it didn't upmix the external inputs (which is why I have always been so confused as to why people seem to advocate for the NX so much?? Seems like a deal breaker to me).
Power is as you say: +12V molex to Extigy, powers on with my Opus. You could also take it off the ignition if power consumption is an issue but then you'd have the problem of losing the SB when cranking -- I found that this is OK but it doesn't *always* come back on with full functionality, and there may be other standby/hibernate issues that I haven't yet encountered. If taking power from the ignition you basically cause the SB to 'disconnect' from Windows, then reconnect when it comes back on. One other tip is to give the Extigy a dedicated USB port off the motherboard header. For whatever reason my CPU bogs down if I run the Extigy off a hub. Not noticeable when I run FrodoPlayer (not very processor intensive) but impossible to run Centrafuse w/ bluetooth audio connection. Hope this helps.
