Old 02-08-2005, 10:46 AM   #1
Schimmel03 is on a distinguished road
Space between sub and back of box
I'm in the process of building my custom enclosure in my spare tire well and I am at a stand still. Reason being, if I want to flush mont my sub with the trunk floor I'll only have 1/8th inch between the back of the box and the bottom of the sub. How much space is there supposed to be here? Is there a minimum? Any help you guys could give me would be great! Thanks!!
Eric
Schimmel03 is offline   Reply With Quote
Old 02-08-2005, 11:16 AM   #2
StationRocket's Avatar
StationRocket is on a distinguished road
I had a similar situtation in my install. you can see it here
http://www.mp3car.com/vbulletin/show-off-your-project/34240-stationrocket-wrx-done.html
I have a Diamond Audio 10" sub in a .5 ft3 sealed enclosure with about 5/8" between the back of the magnet and the floor of the enclosure. It sounds great.
I think you want to have a little bit of room back there so you don't cause acoustic problems but the back of the magnet isn't going to move so you don't have to worry about it crashing. I believe if you put some kind of fill in teh box you will minimise the potential problems caused bu the tight clearence. I got some from www.partsexpress.com they have lots of good parts for this sort of thing but i don't think the actual subs they carry are all that great.
Also what sub are you using? There are lots of different subs out there with very different mounting depths. You may be able to get one that isn't so deep.
Are you taking out the spare tire? If yes it seems to me you should have pleanty of room for even a big sub. I left mine in there and managed to fit it in. My hard time was getting enough volume in the enclosure.
StationRocket is offline   Reply With Quote
Old 02-08-2005, 11:52 PM   #3
carputervirgin is on a distinguished road
does your sub have a vented pole on it? if it does you should have a least an 1/2 of space between your box and you magnet
carputervirgin is offline   Reply With Quote
Sub box rattling!!! ddt General MP3Car Discussion 17 04-07-2003 11:28 AM
