Old 02-08-2005, 05:41 PM   #1
Poet Laureate
rustyboxx's Avatar
Location: The Côte d'Azur of England - Hot totty central
rustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud of
Connecting audio to H/U RCA's
2 quick questions.
Would connecting the line out from an Epia M10000 directly to the RCA cd changer inputs on the back of the H/U (Panasonic CQ-R115SEUC) be ok? I'm a bit loathe to try just in case it trashes the H/U.
Is there a work around for the din connector so that I can disconnect the cd changer and retain cd switch function on the H/U?
RCA's on the left are audio in, the other two are pre-amp.
Thanks guys.
rustyboxx is offline   Reply With Quote
Old 02-08-2005, 06:00 PM   #2
jay_tu's Avatar
jay_tu is on a distinguished road
Exclamation As far as i know....
Hey I also have a panasonic HU, with sane ports on the back, you can't connect them directly to and source for it to work as an aux port. I searched a lot to see if there was any way that I could keep my HU and use it but "NO", the rca for the cd changer only work for a panasonice cd changer that also gets plugged into the other connection, couldnt find a way around it, I wish someone on here comes up with a way to do it.
The pre amp out's can be used but then since they are rear preamp outs, your front speakers will still play whats in the cd or the radio, I found it very frustrating, but panasonic doesnt make a aux port conversion adapter...
SO good Luck let me know if you find a way around it.
jay_tu is offline   Reply With Quote
Old 02-08-2005, 06:42 PM   #3
Poet Laureate
rustyboxx's Avatar
Thumbs up
Curiosity got the better of me. I plugged an audio cable from an old casio lcd tv headphone socket into the RCA's but leaving the cd changer din in place. The head unit still displays the cd details but the audio from the tv came through the H/U with no problem. Admittedly it was only on one channel but I think the audio jack on the tv is mono anyway. It seems as long as a cd is playing in the changer the H/U will stay in cd mode despite the different audio feed.
I guess the principal will be the same when connecting from the mobo. When my pc gets delivered I'll try it and let you know. Unless, of course, in the mean time someone else in here knows different.
Old 02-09-2005, 01:59 PM   #4
jay_tu's Avatar
which RCA's did you use
Did you use the RCA's for the cd changer ? or the pre am out's ?, coz for mine when I used the cd changer RCA;s i didnt get any sound...
Old 02-09-2005, 02:11 PM   #5
Poet Laureate
rustyboxx's Avatar
I just took out the cd changer leads and swapped with the ones from the tv, got sound straight away. Later tonight I will try it with portable cd player that has a stereo phono output and see if that works too.
Probably a dumb question but did you leave the cd din plug in, turn the volume up on what you had plugged in, etc?
Old 02-09-2005, 02:35 PM   #6
jay_tu's Avatar
No if...
If you mean to ask if I had anything plugged into the cd changer DIN... then no, I dont have a CD changer...
All I tried was plug in rca pair, and tried changing the vol level, but no luck after that either...
Hope I understood what you were trying to ask
Old 02-09-2005, 02:51 PM   #7
Poet Laureate
rustyboxx's Avatar
Is the connection configuration on the back of your H/U the same as mine (see earlier photo)?
If so, you need to plug a changer into the din in order to access the cd facility. When the changer is connected and a cd is playing the audio is picked by the H/U irrespective, it would seem, of whether it's from the changer or another source.
I guess to sum it up - no cd changer = no audio from the RCA's. Unless of course someone here knows how to fool the H/U with a DIN thingy!
Old 02-09-2005, 03:12 PM   #8
jay_tu's Avatar
Yes, its the same config., as yours.
And I dont have a CD changer, so I guess no sound comming out of the RCA's ..
Old 08-01-2005, 07:24 PM   #9
Poet Laureate
rustyboxx's Avatar
Wow, not seen this thread for a while, eh Scouse?
Only true postwhores remember everything they post
REP CLUB IS DEAD
LONG LIVE REP CLUB
OEM Navigation Connectors Mr Castulucci General Hardware Discussion 14 07-22-2007 05:31 PM
Carputer integration with HUGE car audio system, help please septicdeath Newbie 19 12-04-2004 06:37 PM
XMDirect Digital Audio Project ? Retsaoc General Hardware Discussion 1 10-11-2004 10:26 PM
XMDirect Digital Audio Output ? Retsaoc General Hardware Discussion 13 10-11-2004 09:10 PM
Seperate VGA and S-Video with Audio Fox_Mulder General Hardware Discussion 7 07-01-2004 02:44 AM
