Old 02-09-2005, 05:13 AM   #1
SwapMeet is on a distinguished road
How to secure a subwoofer enclosure?
I picked up a pre-fabricated subwoofer enclosure to hold me until I have the time, money, and resources to custom build something for my 2000 Ford Mustang. What's the best way to secure this thing so that it doesn't bounce around all over the place? The Mustang's trunk floor isn't sold. It's a thin piece of plywood covered by carpet and it rests on top of the spare tire. There are a few places where I may be able to attach a bracket or something to the sub, or maybe screw in nylon earthquake straps or something similar. Any suggestions?
SwapMeet is offline   Reply With Quote
Old 02-09-2005, 06:03 AM   #2
Nic
Nic's Avatar
Nic is on a distinguished road
velcro tends to work well if you have enough of it
Signature: [==||========] 20% complete
Nic is offline   Reply With Quote
Old 02-09-2005, 08:23 AM   #3
Top Ramen
lgbr's Avatar
lgbr has a little shameless behaviour in the past
Velcro is a good idea. I used to have this problem with the subs sliding around until I just had so much stuff in my trunk that I make an arrangement that would allow nothing to move (it's tricky). The little wood board with carpeting over it sucks, don't drill into it, it wont work.
One thing I did do, was at the home depot they have these little corner brackets, and they fit over a square corner, so you drill them into your car, put the subs in the brackets and it wont move.
Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
Head units are for cheaters!
Quote:
sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
lgbr is offline   Reply With Quote
Old 02-09-2005, 08:36 AM   #4
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
back strap and screws.....same idea as the corner brackets.....
velcro won't do much if you drive in any aggressive fashion ever....not to mention that if the weight of your sub/box combo is a decent amount, velcro wont do much either
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 02-09-2005, 08:54 AM   #5
Nic
Nic's Avatar
dont underestimate the power of velcro, have u seen the things where you get in a velcro suit and trampoline yourself against a wall. If it can be securely fixed (mines bolted right through the car) i guess thats better, i still like velcro tho
Old 02-09-2005, 09:10 AM   #6
_
yes - I've seen/done the wole velcro suit thing....but the thing is....how do you secure the velcro to your carpet? if you can't then what good does it do you? you can't just stick it on the carpet....many times that velcro is stronger than the glue that's on the backing...
Jan Bennett
Old 02-09-2005, 09:22 AM   #7
Nic
Nic's Avatar
yeah it only works if you have carpet that is like loop velcro, then you can cover the bottom of the box with the hook type velcro
Old 02-09-2005, 09:38 AM   #8
wizawuza is on a distinguished road
the non fuzzy side of velcro can stick to the carpet of your trunk usually (well, the carpet in my trunk at least).
So just put the "loop" side of the velcro onto the sub enclosure... and throw it into the trunk. Of course test whether the loop side will indeed stick to the trunk's carpet first.
edit: left this thread window open way too long so that Nic responded while the last post I saw was from red gti. So yeah, just listen to what nic said.
wizawuza is offline   Reply With Quote
Old 02-09-2005, 09:41 AM   #9
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
thats what I use to keep mine from moving around, the hook side of the velcro, granted I only have a single 10" box but it hasnt moved yet.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 02-10-2005, 08:37 PM   #10
starfox's Avatar
starfox
Velco is not permanent, which is good because it's easy to remove, but it's also bad because it's easy to remove (if you can take it out without a screwdriver, so can a car theif)
starfox is offline   Reply With Quote
Old 02-11-2005, 09:57 AM   #11
_
you can't always live you life in fear that people will screw you.....if they get into your can and CAN'T get what they went in for easily...chances are they will be ****ed and will tear up other things just to let you know that you ****ed them off
Jan Bennett
Old 02-15-2005, 08:31 AM   #12
Unfortunately, my car's trunk flooring isn't solid. It's a thin piece of plywood/cardboard that sits on top of my spare with the carpet on top. Velcro probably wouldn't work. I'm tempted to just rip out my spare tire, but I'd have to fabricate a new floor in my trunk. I may secure it from the top using some metal brackets
Fiberglass Sub Enclosure project shillier Fabrication 26 02-06-2009 04:30 PM
building an internal enclosure sevsev General Hardware Discussion 3 09-21-2004 05:05 PM
slim optical enclosure with internal battery zPilott General Hardware Discussion 0 08-23-2004 07:29 PM
dvd external enclosure drive kuo General Hardware Discussion 19 03-07-2004 05:36 PM
Subwoofer Enclosure Q-Value ??? Raas Off Topic 4 05-22-2002 08:23 AM
