Old 02-11-2005, 12:02 AM   #1
dyeinbreed is on a distinguished road
weirdness with power block.
I have a tsunami fuse block (http://www.partsexpress.com/pe/pshow...number=263-134) and since I did all my wiring today I figured id hook this up and be set.
A couple questions.
It beeps REALLY loud when the car is started for like 5 min, then eventually stops. Im assuming, and hoping this is not normal for it. What could it be?
Im assuming its 'Audible blown fuse and high/low voltage warning'
reading that I now realize that this does not come with fuses, where do the fuses go on this thing? I dont really see a spot for them. Would any automotive site have these mini-anl fuses or are they mainly used for audio equipment?
dyeinbreed is offline   Reply With Quote
Old 02-11-2005, 12:14 AM   #2
Nic
Nic's Avatar
Nic is on a distinguished road
the fuses go in the clear window between the screws at the top and the bottom, mini-ANL fuses are a car audio thing, go looking at car audio places or in the car audio section of shops
Signature: [==||========] 20% complete
Nic is offline   Reply With Quote
Old 02-11-2005, 09:56 AM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
lol - classic......
sorry - just had to laugh
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 02-11-2005, 12:55 PM   #4
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
We're going to see his car aflame on the side of the road one of these days, I believe.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 02-12-2005, 04:40 PM   #5
yeah you guessed it champ.
im new to car audio thats all.
Old 02-13-2005, 08:44 AM   #6
_
one quick question.....did you look for a fuse rating or anything on that Tsunami piece? to assume that it came with fuses you must have at least checked to see that it had a fuse rating for the entire thing....you would have needed to check and see what the ratings were on the fuses to match it to your needs......if you don't match your fuse ratings you can get yourself in some serious doo doo
Jan Bennett
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
Simple Idea for keeping power to inverter while cranking.... syclone477 Power Supplies 1 03-23-2004 10:03 AM
Opus power supply issue dmazyn Power Supplies 2 10-15-2003 07:32 PM
Brief power loss between ACC and start Destin General Hardware Discussion 20 01-26-2001 11:12 PM
HELP!! Power Supply wont supply power Saab General Hardware Discussion 3 08-28-2000 10:33 AM
