02-13-2005, 05:53 PM
#1
1-DIN Project cases ?
Does anyone know where i can purchase a single DIN metal case for a project ?
Jan
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
02-15-2005, 01:46 AM
#2
I have one of those Casetronic C134 mini-ITX cases and it is DIN alright but the case was too deep to mount in my dash, my car: Subaru WRX STI -2003!
So make sure you have enough room to fit these cases!
I am going for a custom made one instead that can fit both lilliput and m10000: www.tmz.com/wrx
/L-O
02-15-2005, 08:03 AM
#3
_
other than those cases, I don't think you have much of a choice....
the fact is that with computer components you can't really get much shorter....=/
02-15-2005, 08:06 AM
#4
Well, the new nano-boards that is coming in a 12*12cm size :-)
02-15-2005, 08:08 AM
#5
_
yeah - but it's not out right now so it's not exactly in the picture yet is it
02-15-2005, 01:18 PM
#6
the nano is not small enough for my project, it's a 1-din autopc with slotload dvd and in-dash 7" tft. the mobo i am using is a PC104 sized PIII/Celeron board from Kontron, it's only 96x90mm in size and only needs +5V, no ATX PSU needed = more space for HW
Jan
02-15-2005, 01:21 PM
#7
hmm, guess i'll have to build my own case then, none of logicsupply's cases are what i am looking for.
02-15-2005, 01:41 PM
#8
You want to get rid of that (casetronic c134)case that won't fit?
02-15-2005, 07:12 PM
#9
Clean the guts out of an old headunit?
02-16-2005, 04:01 AM
#10
yeah thats what i tried will its not really handy to much things inside and not really smooth, just get a sheet of aluminium and make you're own.
i'm interested to in the c134 heheeh
my destinator map resource down permanently
02-16-2005, 04:13 AM
#11
Hi Jan!
How much is the PC104 sized PIII/Celeron board?
I would consider this if the pricing is in line with the EPIA-boards since the size and power-requirements seems really good...
/L-O
02-16-2005, 04:40 AM
#12
I was thinking...
What if I removed the guts from my old cassette player, kept the amplifier and connected it to the line out of the pc, use a slot dvd for the drive, a CF for booting a live OS (maybe some handmade XP embedded). I might also try to use-modify the PSU of the head unit.
Any thoughts on that approach?
Well maybe with nano-itx things would be more easy...
02-16-2005, 10:48 AM
#13
Well, the one i am thinking of getting is this one : http://www.nbn-online.de/PC104_plusCPU.htm called mopslcd7 which starts at 299 EU only abit more than say a MII-10000 epia.
Jan
02-16-2005, 11:02 AM
#14
I'm not sure if you can fit indash-lcd along with the dvd-rom and mobo into 1Din case.
It just too much for a single unit. Other that that, you can get all the drawings from my side to build the 1Din metal case for EPIA-M mobo.
02-16-2005, 11:06 AM
#15
Registered User
EPIAM-M fits with snap-in DC-DC power suply (such as PW-70A), slimline DVD and CF/IDE card adaptor in 1DIN chassis. All you have to do is use low profile memory and lower (then standart) standoffs for motherboard. tested.
| Thread Tools |
| Display Modes |
Linear Mode
