Old 02-15-2005, 09:08 PM   #1
gleinz
Wiring up the system... got a few ?s
I'm almost done with this project... just ordered an amp and now I just need all the wiring to hook it up. Right now I'm going to run the amp and an inverter from my battery, but later replace the inverter with a DC-DC power supply. So either way, I need to run two things from my battery...
My question is, what's the best way to do this? I've been shopping around lately, and seen places like Crutchfield selling "battery terminals" which just look like covers with places to connect 2 power cables and 2 ground cables (on the respective terminals of course). Should I do something like this or just hook them directly to the battery? If I do get the terminals, what should I look for?
Thanks, and let me know if I confused you, because I sort of confused myself.
- Matt
2004 WRX Carputer
gleinz is offline   Reply With Quote
Old 02-15-2005, 10:56 PM   #2
Well, He asked for it.
WebDog's Avatar
WebDog will become famous soon enough
Well depending on the amperage you will need you could run a 4 or 8 gauges wire from the battery I recommend a 4 gauge then you can put a distribution block and make it to 2 8 gauge wires. One to the inverter and one to the amp just make sure to get the proper fuse 12" from the battery; I am using a 100AMP circuit breaker for my system just to make it easier on me.
Then you just ground it 12-18" from the amp/ inverter with the same gauge as you have from the distro block.
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
WebDog is offline   Reply With Quote
Old 02-17-2005, 12:47 AM   #3
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
I'm confused,
I think those terminals your talking about are exactly what you would use to connect directly to the battery, how much more direct could you get?
turbocad6 is offline   Reply With Quote
Old 02-17-2005, 02:08 AM   #4
WebDog's Avatar
Here is a few images that show what i was talking about.
1990 Jeep Cherokee
Need help with wiring a system ClubFed11 Car Audio 18 01-05-2005 06:54 PM
my planned system link138 General MP3Car Discussion 6 08-13-2004 12:58 AM
Building Smart Car System, need advice, help BugNuker Newbie 7 08-04-2004 09:16 PM
Car with no system..How do I wire the speakers to my MP3 system? fogleroller General Hardware Discussion 10 02-14-2002 03:46 PM
