Old 02-15-2005, 09:55 PM   #1
heynicecar is on a distinguished road
VW owner help me out
are you guys using crossover for your tweet and woffer then to the amp or you just running to the amp from the speaker. i got an gti with monsoon system. i'm running the wire from the harness in the back of the hatch.
thanks
heynicecar is offline   Reply With Quote
Old 02-15-2005, 10:01 PM   #2
strohj's Avatar
strohj is on a distinguished road
are you still gonna use the monsoon amp? .. cos if you are.. it has a crossover builtin for each speaker
strohj is offline   Reply With Quote
Old 02-15-2005, 10:09 PM   #3
i'm not using the monsoon amp i'm not running a head unit.
Old 02-15-2005, 11:01 PM   #4
ppgt94's Avatar
ppgt94
You're probably going to blow your tweeters w/out a crossover.
ppgt94 is offline   Reply With Quote
Old 02-16-2005, 08:33 AM   #5
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
you need to run a cross over to bump the voltage up to something acceptable for most amplifiers.....in that sense yes, if you don't so it you could blow your speakers....
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 02-16-2005, 06:25 PM   #6
ppgt94's Avatar
ppgt94
A x-over into amp?
Most (decent quality) amps have a x-over built-in.
Old 02-16-2005, 10:10 PM   #7
_
some cross overs out there can also bump voltage, but what I ment to say was EQ....
what's of most concern is the voltage here - the voltage coming out of a mobo sound card is less than 1volt....not near enough to supply a clean signal to an amplifier....
Jan Bennett
Old 02-16-2005, 11:14 PM   #8
ppgt94's Avatar
ppgt94
I haven't noticed any real problem and I have no preamp in between the sound card and amp. What are you using?
Old 02-16-2005, 11:48 PM   #9
TheLlama's Avatar
TheLlama is on a distinguished road
I'm not a VW owner, but you can probably get by putting a passive crossover between the woofer and tweeter. You can make a simple passive crossover with a capacitor and resistor just . May sure you note the impedence of your speakers and amp.
TheLlama is offline   Reply With Quote
Old 02-16-2005, 11:54 PM   #10
cbergeron's Avatar
cbergeron is on a distinguished road
If you're going super high-end you would put the X-Over before the amps. Using a 6 channel X-Over you can direct which frequencies go to which amps. You save the amps from having to do the crossover work.
It also gives you the advantage of a single point of tuning. You can tweak one area instead of 3 different amps and their hi/lo/ x1 or x20 settings, etc.
It makes thinks much cleaner to have a separate Xover before the amps, in my opinion.
HTH,
CB
DashPC - The Linux Car (since 1999).
Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
As seen in the book Geek My Ride
cbergeron is offline   Reply With Quote
Old 02-17-2005, 08:10 AM   #11
_
well, to say that you haven't noticed a difference doesn't say much....it also depends on the quality of the rest of your system...
the amps I'm using donb't come into play here since I'm not having a problem with my sound quality or signal quality, nor did I ever just run the signal direct to the amps from the onboard sound from the computer....
btw - I am using Arc Audio 4150 and a 2500....
Jan Bennett
Old 02-17-2005, 11:45 AM   #12
TheLlama's Avatar
I agree, and active crossover on the line level would be ideal. However, you will need to have 4 channels of amplification for your front speakers. So if you have 6 channels you can provide to the 6 speakers, then go for it. However, if you only have a 4 channel amp (or two 2 channels, whatever) then I would recommend using a passive between the woofer and satellites. Mine is wired this way and it sounds fine. Most of the sound mixes anyways, this just ensures that the tweeters don't erupt.
Old 02-17-2005, 12:40 PM   #13
_
active is a beautiful thing!
but then again I am running a 4 channel amp to my mids and highs and running the PXA-H700 processor
Jan Bennett
Old 02-17-2005, 12:46 PM   #14
thanks guys i ran crossover to all my speaker and its working good now thanks for the help.
Old 02-17-2005, 12:58 PM   #15
ppgt94's Avatar
ppgt94
I wasn't asking about your main amplifiers. You said you had a EQ before the amp to boost the signal from the sound card.
VW Owners / Dimming lights TheSpatulaOfLuv Power Supplies 16 09-16-2005 08:48 AM
1997 VW Jetta GLS Install SiGmA_X Show off your project 22 08-22-2005 05:36 AM
Nice device for VW Beta?? Enigmaster Car Audio 0 06-13-2004 03:33 PM
VW Wait skin Alric MediaCar 2 03-27-2004 11:32 AM
1998 VW GTI VR6 Project Stavros Show off your project 17 01-27-2003 12:16 PM
