Well the 6-disc in-dash receiver in my Ford Focus is on its last leg. Everything has been stripped so much the mechinisim that moves the CDs no longer works right. It barely plays anything anymore.
Do any one of you have so recomendations on a good HU? I want one that at least has the following features:
Aux Input (on the rear!)
RDS (Radio Data System, shows song titles, call letters, etc.. nearly every major station in the US is broadcasting this now!!!)
Seperate and adjustable Sub Out, built in crossover would be a definate plus!
Mp3 playback
multiple line display with named mp3 folder navagation, not numbers like I have seen on a lot of HUs
display that actually shows full name of mp3 being played
actual adjustable EQ would be great too! (not one with just Rock, POP, etc... presets!)
Don't care about HDRadio or XM/Sirius support.
I've looked and not seen so far a single radio that had at least the features above. So maybe someone else on here has!
My Focus is a so called "Mach" edition. Basically its upgraded poly speakers, with a 10" dual voice coil sub in the trunk (with 2 amps) The amps are driven from a single output on the factory HU. I plan to hookup the aftermarket HU right to the factory amps. The amp's input are line level so I won't need any level adapters
