Old 02-17-2005, 10:16 AM   #1
therussman2002's Avatar
therussman2002 is on a distinguished road
stinger sp800 battery keeps dying
my second stinger sp800 battery is dead as of recent
same crap as the first one, wont charge up past 10.7v or something to that effect
i have a zero gauge wire coming from my isolator under the hood to this battery, and off of it are 3 amps and 2 caps, nothing too complicated... the warranty process with stinger takes over a damn month
anyone have any insight or experience in car audio batts that crap out in a few months?
therussman2002 is offline   Reply With Quote
Old 02-17-2005, 12:43 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
how much testing have you done? have you checked your alternator? to make sure that it's charging like it should?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 02-17-2005, 12:49 PM   #3
yes the alternator charges my hood battery just fine
i have an isolator that separates my two batteries, so that they are not charging off each other even when the car is running
i have to run a small wire with a diode from the hood battery to the alternator, for that sensing crap, so it knows how much to charge
i had this theory that if the front battery was charged, the alternator would know this, and stop charging, and therefore not fully charge the rear battery
but when i place this wire&diode between the trunk battery and the alternator, the alternator does not put out any voltage, as if there was no battery there
i first noticed the problem when my 3 amps were just cutting in and out constantly after a minute of going on the road, i checked my remote wire and some other things, and eventually checked the voltage of the trunk batt when the car was off: 10.7
Old 02-17-2005, 01:00 PM   #4
mbuchman's Avatar
mbuchman is on a distinguished road
Have you hooked up the battery to a charger to try to charge it back up? I personally agree with Red GTI in thinking its alternator issues. Either that, or a loose wire may cause it to lose the power.
Matt
mbuchman is offline   Reply With Quote
Old 02-17-2005, 01:03 PM   #5
Matt
nah havnt tried a charger yet
thing is it charges my front battery just fine... i measure the voltage of the whole system and its 14-15
if i had alternator problems then the car wouldnt be running as fine as it is, the many days since my amps started doing wierd things
Old 02-17-2005, 01:45 PM   #6
mbuchman's Avatar
I was just thinking that if the batteries are in parallel, that means that each one of them gets 14.4 volts from the alternator, but your radio may use up all of the alternator that is not used by your regular battery, leaving your second battery uncharged. Know that it is a little out there, and I dont feel like doing the math to figure out if that explanation is reasonable (because although voltage is the same, current is different, so I dont know if the difference in current would cause the main battery to be charged less or what, and really dont want to try to figure it out )
I would just try to charge it with a charger, and if the battery doesnt pick up, then at least you know it is a bad battery. Maybe a yellowtop would be good for you? Dont really know how they compare, but I just know yellowtops are used a lot.
Matt
Old 02-17-2005, 02:12 PM   #7
_
the stinger batteries are decent - but for the money I would go with a yellow or a red top any day....
I ran two SP1700s from stinger in my car back when I was competing in SPL (4 12s on a US2000 amplifier in a GTi) - the batteris were like bricks.....no matter what I threw at them they charged back up just fine - was able to run my system with the car off, at 3/4 volume for 4 hours, and still start the car without a second thought...
but.....from what I have heard about their batteries as of late....they aren't all that great....
Jan Bennett
Can I put an extra battery in my Chevy? Mastiff Power Supplies 14 11-04-2008 12:45 PM
Voltage drop using Stinger S1602 Battery Isolator therussman2002 Car Audio 2 02-01-2005 10:56 PM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 10:31 PM
time to a dead car battery? chuckctv Newbie 8 08-24-2004 03:47 PM
time to a dead car battery? chuckctv Newbie 6 08-20-2004 11:08 PM
