The MP3car.com Store
Thread Tools Display Modes
Old 02-21-2005, 12:15 PM   #16
Stank Cheese
n8scstm's Avatar
Vehicle: 2001 Chevy Silverado escalade front end Posts: 69
My Photos: (0)
I have an optima d31T. It's the biggest optima there is.
http://search.ebay.com/optima-d31t_W0QQfkrZ1QQfromZR8
I ran my system with 15 inch screen in my truck for 6 hours before the inverter shut down due to low voltage. I dont know anything about the stingers but would personally go with the optima because its a bigger brand and warranty replacements will be a lot easier. I got mine from auto zone so if I need a new one they can have it to me in hours.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
n8scstm is offline   Reply With Quote
Sponsored Links
Old 02-21-2005, 12:40 PM   #17
kozmo's CarPC Specs
Vehicle: 1996 Chevrolet S10 Pickup
My Photos: (0)
Quote: Originally Posted by Olly H
I've never heard of people damaging deep cycle batteries by not fully discharging them.
I know for a fact that the Optimas can be partially dischrarged and recharged without causing problems.
Nate
I know what yer thinkin...did he fire six shots or only five...
kozmo is offline   Reply With Quote
Old 02-21-2005, 12:50 PM   #18
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
I would hope any battery can be PARTIALLY discharged without a problem....other wise, it's a pretty shiesty battery....lol
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 02-21-2005, 08:12 PM   #19
My Photos: (0)
If I was to add a battery it would be a deep cycle battery with a split charge relay.
That's exactly what I have. Optima Red starter, through an isolator to a Yellow. The Yellow only starts charging once the Red is topped up. All electrics run off the yellow, including stereo and fridge.
You won't damage it, but if you repeatedly discharge it by only 10-15% you may well decrease its usuable life. But also keep in mind that even with a deep cycle battery, discharging it completely will do more damage. As a rule of thumb, if it drops below 10V, charge it up.
froop is offline   Reply With Quote
Old 02-22-2005, 06:25 AM   #20
My Photos: (0)
common name for that is "muscle memory". old cell phones were notorious for that, that the phone would eventually learn your standard discharge point as fully discharged, soon your phone only lasts 2 hours before its dead. Now we know our modern cell phones have beaten this problem, that they dont succumb to muscle memory.
does the optima? does the stinger? does the die hard? Dunno. but it might be worth asking someone who does know beyond any reasonable doubt.
WhiteRabbit is offline   Reply With Quote
Sponsored Links
Old 02-22-2005, 03:10 PM   #21
Top Ramen
lgbr's Avatar
Vehicle: 1991 Toyota MR2 Turbo
My Photos: (0)
Quote: Originally Posted by froop
Deep cycle batteries are designed to be just that - deep cycling. That means charge them, then drain them down to just about flat. A starting battery is just about the opposite - draining it down to flat damages it.
Deep cycle - charge, use completely, charge...
Starter - charge, use moderately, top up, use, top up...
A deep cycle battery will often have enough CCA (cold cranking amps) to start you car, and although a starter battery may have a similar amp-hour rating to a deep cycle, draining it flat by pumping the tunes without the engine running will kill it.
Likewise, if you're pumping the tunes with the engine going, you're better off saving your money on your battery, and upgrading your alternator so it can keep your starting battery fully charged.
The biggest gain of an Optima (red, blue or yellow) is that they have bloody quick charge times compared to most standard batteries. But you still need your alternator to be able to charge the baby up!
If you want the best of both worlds, get a red top to power your amp while you're driving, and flick it over to a yellow if you're cranking volume up with the engine turned off.
I still don't see what your point is. The deep cycle batteries have the same CCA rating, yet they charge quicker. My Optima has performed great for starting. 550 CCA's, and I've started it in sub-zero temperatures easily.
Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
Head units are for cheaters!
Quote:
sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
lgbr is offline   Reply With Quote
Old 02-22-2005, 04:51 PM   #22
Stank Cheese
n8scstm's Avatar
My Photos: (0)
An optima yellow top is a dual purpose battery. Good for both.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 02-22-2005, 05:15 PM   #23
VanMan69's Avatar
Vehicle: 1995 Chevy G20 Van
My Photos: (0)
I'm running an isolated single-diehard/dual-yellow-top (D34, standard size) auxiliary system.
I couldn't tell you the average runtime with just the computer, because very rarely do I run out of juice using just the computer (have watched movies back to back to back). That's with the comp, HU & two front speakers, & 15" monitor.
I can leave the computer on (idling) for over 8 hours (couldn't say how long really, but basically I've left it on all day while at work, with still juice to go).
I can run comp, two xenarcs, HU w/ 2x50w front speakers, 2x100w rear speakers, 2x300w subs at top volume for over four hours on a good charge.
These are top charge times. If I use stuff for four hours, then drive for 15 minutes, it won't last four hours again without a good charging.
Don't know anything about Stingers.
95 Chevy G20 Vroom Boom Room
...with a whole bunch of nifty ****... go check it out: VanDomain Page
VanMan69 is offline   Reply With Quote
Old 02-23-2005, 06:10 PM   #24
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (77)
to me the stinger & the optima are very similar, I don't know how much it even matters which is better, I use optimas because they are convinient & cheaper for me, but the stinger is also fine.....if your really looking for "the best" you want to start looking for lithium ion batterys I think. this is the latest commonly available battery source with no memory affect & long run times, problem here is that they cost a fourtune to get as much power as an optima or stinger provide,probably wind up being a bank of smaller ones. I never really looked into the availability of large li-ion's, anyone?
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 02-24-2005, 05:00 AM   #25
My Photos: (0)
Man, there are people here that have no idea what they are talking about... The typical " BUY IT BECAUSE " types.... But. there are a few that have half a clue
Yes, the deep cycle is NOT good for starting, it is the WORST thing!! You will pull all your juice FAST... A deep cycle should NOT be charged fast eaither, ie: alternator, because it can be damaged. The deepcycle is a slow discarge, slow charge battery. This will make it last for a VERY LONG TIME. the yellow top they say is a starting and deep cycle, take this with a grain of salt, it won't last long if you use it as a primary battery........ You need to use a battery isolator with a deepcycle and use another battery such as a red top with a deepcycle and this will keep your deepcycle lasting a long time.
kenski is offline   Reply With Quote
Old 02-24-2005, 07:14 AM   #26
_
My Photos: (90)
kenski - I've had this discussion on this forum like 5 times with different people. I agree 100% with you on this. But I've also come to realize that people like to believe that they are right, no matter what evidence is given to them.
It's a futile effort....lol
Jan Bennett
Old 02-24-2005, 07:52 AM   #27
My Photos: (0)
hahahahaha ya, thats the power of the internet.... Everyone is an expert behind it.....
Like the Holiday Inn comericals.......
Old 02-24-2005, 07:54 AM   #28
_
My Photos: (90)
that would be a good pic for this thread.....
"i'm not an expert on batteries, but I did stay in a holiday in last night!"
lol
Jan Bennett
Old 02-24-2005, 10:35 AM   #29
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
Excellent read..
You guys saved me 187 CDN. Was going to buy an Excide deep cell and use it as starter battery. OK so what is a good starter battery then?
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 02-24-2005, 01:30 PM   #30
_
My Photos: (90)
IMO: red top optima
Jan Bennett
Sponsored Links
Trackbacks are Off
Optima batteries -> Venting? kiltjim General Hardware Discussion 12 09-30-2004 07:56 AM
FS: SF Bay Area: Optima Yellow Top VanMan69 Classified Archive 2 08-19-2004 03:17 PM
Two batteries in my ride SAScooby Power Supplies 3 05-12-2004 09:15 AM
Optima batteries turbochris Power Supplies 3 05-06-2004 09:54 PM
Powering LCD panel with batteries paulw General Hardware Discussion 7 11-01-1999 01:37 PM
Sponsored Links
Ad Management by RedTyger
