The MP3car.com Store
Thread Tools Display Modes
Old 10-14-2005, 12:41 AM   #46
Vehicle: Bravada - Triplet
My Photos: (0)
deepcycle = steady power draw for extended period of time (e.g trolling motor, golf car, etc...)
Cranking battery = High demand for short period of time (starting your car)
Both will handle many, many charge cycles, however, deepcycle could be fully drained while a cranking one can't handle depletion.
Ask any one that owns a fishing boat, we all have 2 batteries, one to start the outboard and the other (deepcycle) for trolling motor, gps, sonar, radio, lights, etc. Those deepcycle can keep you on the water for up to 8 hrs running at 42 thrust and yet, they will die if subjected to sudden current demand, that is why it is recommended that when starting the trolling motor, make sure it is set to low speed and then ease your way up.
DO NOT use a yellowtop as starting battery, it will not last even though it is dual purpose, occasionally, yes, on daily basis, no.
Just my 2 volts.
kingtut is offline   Reply With Quote
Sponsored Links
Old 10-14-2005, 10:09 AM   #47
sdashiki's Avatar
Vehicle: 2003/Toyota/Matrix
My Photos: (0)
Um I dont understand when someone says
"A new alternator needs to be considered also. The factory alternator is designed to provide enough current to charge the battery while running the car and it's accessories. If you add an extra current draw to the system chances are you will run out of current supply."
because if you use an isolator, how can you draw extra current from the alt? The second battery isnt there creating an extra "current draw", it is there as a tank to keep your starting battery from ever feeling a drain from your electronics. Right?
I mean yeah the alt is now charging two batteries, but since your starting battery isnt really being used except for your headlights and AC how can keeping the deep cycle topped off be an extra drain?
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
sdashiki is offline   Reply With Quote
Old 10-14-2005, 02:01 PM   #48
SickVette's Avatar
Vehicle: 1999 Corvette / 2004.5 Chevy Silverado 3500 dually/ 2004 Suzuki GSXR 750/2006 Suzuki GSXR 1000
My Photos: (0)
I think some people here are missing the definition of deep cycle. Deep Cycling - The process of drawing a high percentage of a battery's capacity (deep discharging) and recharging it to full capacity. Any battery can be deep cycled but unless it is designed to it will not return to full capacity.
sdashiki....would you add a second battery to your car if it was stock? Obviously there is aftermarket electronics in the car to warrant a second battery. All to often people add another battery to the auto in hopes of fixing low voltage or lack of current in the system. That is the job of an alternator. Now when you add a second battery your alternator must keep the car running and both batteries charged even if there is an isolator. Let's say your alternator was running full capacity for 50 % of the time before installation of electronics and second battery. Now it must run full capacity 85 % or greater with the addition to the vehicle. yes the alternator might be able to handle but it will not last. It will generate alot more heat which will then cause it to fail prematurely. If you want the most performance and reliability out of your auto's electrical system then an upgraded alternator needs to be used...period.
SickVette is offline   Reply With Quote
Old 10-14-2005, 03:14 PM   #49
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (77)
Quote: Originally Posted by turbocad6
Sorry for the following long post, but ask a complicated question & get complicated answers…
A properly used stiffening cap is to your electrical system, what your shock absorbers are to your suspension. You could drive your car without shock absorbers but the constant pounding will ruin structural components & transfer the shock to the rest of the vehicle, causing your pc to shut down among other things. The stiffening cap will actually prolong the life of your alternator in the same way, by "absorbing" the big instantaneous demands for high current & smoothing them out to a certain point. Just because your caddy has shocks, doesn't mean you can go Baja it off road, obviously a stiffening cap isn't going to cure all & if the overall average draws of the system & the rest of the vehicle is higher than the output of the alternator the cap will not solve your problem. you can't expect a stiffing cap to supplement a true 1000+ watt system, & even a bunch of batteries will only prolong the inevitable of draining your reserves, to run a system that has big power demands you must increase the output of the alternator to meet these demands.
The best solution is a combination of an aux battery close to the amps & a stiffening cap. A configuration like this will allow you to draw up to & even over your alternators output for short periods of time without a problem....
I can't tell you how many bigger systems have been installed, only to need a new alternator within a month or so. This is actually common, especially if your working with a car that has had it's alternator in service for 5 years or more. The main goal here is to absorb the dips & spikes, the headlights dimming are only a symptom of the real problem.
An amplifier instantaneously pulling up to 150 amps or much more in some cases, from your battery for a peak is almost as severe as intermittently shorting the terminals. This will not only overload the alternator, but can also screw with ecm's, bcm's, air suspension and/or suspension controls, not to mention a whole host of other electrical systems in a vehicle, Including your car pc, which doesn’t like an unstable environment, especially electrically.
most of these systems are already being taxed by the fact that they are used in a mobile unstable environment in the first place, & most have been designed to live under these conditions, but add this much more stress & problems can & do occur. This is the main reason that automotive computer systems use say a 5v reference for sensors & such, because they can regulate it & attempt to maintain this constant voltage much more reliably than if they tried to run these systems at full battery voltage, which can easily vary by over 2 volts up or down depending on loads & usage.
the cap can act as sort of a shock absorber, by providing the big instant hit of extra amperage at the right time, thereby taxing the electrical system that much less. Depending on how much is needed this may or may not make all the difference needed. an aux battery in the rear will kind of act as a spring, by being able to help deliver power under those same conditions, but for a longer period of time than a cap. The real difference is how "fast" the power demand is needed. Think of a cap as a sledge hammer, quick short bursts of power, but with a pause in between for recharging (backswing). Now think of the battery as a helper pushing. You will get the best results by having one guy pushing while the other swings away with the sledge hammer, all being perfectly timed by the physics of the demand at hand.
I have built pro systems that will run at say 1,200 true rms, & powered it more than adequate with a 4 gauge run from the front to the rear battery, which is close to the amps. From the rear battery you would give each amp the power it needs, with even a 0 gauge for the sub amp & cap bank, 0 gauge ground to frame. Now keep in mind that the 4 gauges only job is to charge the rear battery, which in turn really supplies the system. The 4 gauge will not be overloaded because on average it is only providing the 30-50 amps required to maintain battery voltage in the rear, & the majority of the quick instant heavy short loads are handled by the rear battery & caps, never actually overtaxing the front of the vehicle itself. This is verified by the fact that I can run this system with an 80 amp breaker inline front 4 gauge without ever blowing it. Actually the only way to blow this 80 amp breaker is if the front battery went dead & then I tried to crank off the rear battery, or boost the vehicle from the rear. This system had a peak draw of almost 200 amps & it never saw the front of the vehicle.
Anyone who tells you that a battery is better, or a cap is better, is not taking the whole picture into account. If I had to choose between one and the other in an install, I would pick the battery, but honestly they work best together. A batcap is kind of a melt between the two, but doesn't achieve the peak benefits of either; sometimes it can be a reasonable compromise when space is restricted...
sorry for the long quote but I didn't feel like doing that much typing again........ basically using a rear battery while the car is running will be the equivelnt of putting a bigger battery in your car..... it is not generally thought that putting a bigger battery in your car is bad for the alternator..... your putting a battery in the rear is the equevilent of one larger battery, but with it being much closer to the amps requiring less gauge wire front to rear than if the only battery was in the front.
killing the batterys obviously will put more strain on the alternator, but the idea is to not kill them
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 10-15-2005, 11:37 AM   #50
accentsound's Avatar
My Photos: (0)
I run a huge Marine Deep Cycle Battery. It's like two standard batteries stuck end to end. Weighs a ton as well. It works like a charm and has not given me a lick of trouble.
We sell both Optimas and Stingers. They are good products, but as with any thing that is sold to the specialty markets, they are expensive.
You did not hear it from me, but run down to your local NAPA and check out their Blue, Red and yellow top sealed batteries. They perform just fine and you'll save a TON of money.
accentsound is offline   Reply With Quote
Sponsored Links
Old 10-23-2005, 02:44 PM   #51
Vehicle: 1994 Honda Accord LX
My Photos: (0)
Speaking of alternators....I'm trying to find some high output alternators for imports anyone know of any places where you can find them? All i see on the forum posts are for domestic cars
HitmanZ is offline   Reply With Quote
Old 10-23-2005, 05:10 PM   #52
My Photos: (0)
google iraggi. nice guy
WhiteRabbit is offline   Reply With Quote
Old 10-23-2005, 05:45 PM   #53
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
ohio generator
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Optima batteries -> Venting? kiltjim General Hardware Discussion 12 09-30-2004 07:56 AM
FS: SF Bay Area: Optima Yellow Top VanMan69 Classified Archive 2 08-19-2004 03:17 PM
Two batteries in my ride SAScooby Power Supplies 3 05-12-2004 09:15 AM
Optima batteries turbochris Power Supplies 3 05-06-2004 09:54 PM
Powering LCD panel with batteries paulw General Hardware Discussion 7 11-01-1999 01:37 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
