The MP3car.com Store
Thread Tools Display Modes
Old 03-02-2005, 05:54 PM   #1
Vehicle: 2006 Rav4
My Photos: (0)
Best way to connect 8 gauge wire to 12-16 gauge wire?
Finally have all my car audio and power parts in (amp, sub, amp install kit). Back seats and paneling have been removed from my car. Have a remote audio video switcher, as well as an inverter and other goodies. Anyway, just a few quick questions:
I will have 4 gauge power cable from battery to to trunk distro block, at which point it will branch off into 3x8 gauge cables to feed an inverter and and amplifiers. These lead back to another ground distro block.
I need some smaller 12 volt power lines to power a Sirius tuner, the amplified video switchbox, and maybe a rear view camera. Whats' the best way to get 12-16 gauge cable from the above setup? It's kinda unwieldy to wire crimp the 8 gauge and 16 cables together. I'm thinking I could solder one end of the 12 gauge cable to one end of the 8 gauge cable and then put that entire assembly into the distro block connector.
Suggestions?
SwapMeet is offline   Reply With Quote
Sponsored Links
Old 03-02-2005, 06:04 PM   #2
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
8 gauge is a little big but.....
you might be able to find something along these lines:
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 03-02-2005, 06:11 PM   #3
_
My Photos: (73)
or this:
Jan Bennett
Old 03-02-2005, 11:31 PM   #4
hd54321's Avatar
Vehicle: 1998/Lexus/ES300
My Photos: (0)
Quote: Originally Posted by Red GTi VR6
or this:
You're just showing off now...j/k - you're setup is tight.
hd54321 is offline   Reply With Quote
Old 03-02-2005, 11:56 PM   #5
Vehicle: 2006 Rav4
My Photos: (0)
Cool, where do I get something like that?
Old 03-03-2005, 01:17 AM   #6
Banned
xdjxklusivex's Avatar
Vehicle: 1995 Suzuki GSX-R 750 / 2006 Honda Accord / 2002 Saturn S / 1997 Ford Crown Vic
My Photos: (0)
ghetto style - twist and electric tape
whatever you want to do man it will work just make sure its a nice tight seal especialy if its coming from ur battery.... why dont u wire the smaller stuff like camera to a fuse under ur dash or something its easier and u can choose if u want it to turn on when u turn the key or alwayz be on... have fun
xdjxklusivex is offline   Reply With Quote
Old 03-03-2005, 06:40 AM   #7
_
My Photos: (73)
lol - thanks
you can get stuff like that at any home depot, lowes, electrical supply store, etc
Jan Bennett
Old 03-03-2005, 06:41 AM   #8
_
My Photos: (73)
this is about the most unprofessional way you could do it. it's not secure, and it's far from pretty, not to mention unsafe...
but the fuse thing makes sense
lol
Jan Bennett
Old 03-03-2005, 07:33 AM   #9
Nic
Nic's Avatar
Vehicle: 1993 TX3 Laser
My Photos: (0)
lol
it may not be the best method but it works, it works especially well if you solder the wires then tape them up. i find connections where whe wires are only twisted and taped to hold up to abuse much better than any of the crimp style connectors commonly used
Signature: [==||========] 20% complete
Nic is offline   Reply With Quote
Old 03-03-2005, 07:49 AM   #10
MySQL Error
Scouse Monkey's Avatar
Vehicle: Pug 306 & BMW 325i
My Photos: (0)
Anyone used these things for splicing in?
http://cpc.farnell.com/jsp/endecaSea...CBA-560B&N=401
Could be ok for low power things
And red, i have to second that - you are such a show-off But i am being jealous - wish i had the time, money and skills to make something that nice.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Sponsored Links
Old 03-03-2005, 08:16 AM   #11
_
My Photos: (73)
you must not be crimping them right then, or something, because a correctly crimped joint will outlast a twist and tape any day.
And yes, a solder joint with tape over it would be a nice option, but not very user friendly when it comes to taking stuff out etc..
that's why we went with the strips in my car, to get the amp rack out we can just disconnect at that strip, disconnect the power, ground and remote leads at the other strip and dist. block, and unscrew the rcas....pull the entire amp rach out and not have to worry about running it all back through the tubes....because that was a PITA!
just giving him options that are user friendly
Jan Bennett
Old 03-03-2005, 08:18 AM   #12
_
My Photos: (73)
how is it showing it off??
I guess I should have spent the time to find a picture of those online somewhere else hu?
btw - those t-taps are ok, just not for 8 gauge wire.....but you won't find any t-taps near my car (unless they are there from the factory) (btw - THAT comment MIGHT be considered showing off a little....lol)
Jan Bennett
Old 03-03-2005, 10:50 AM   #13
Vehicle: 2006 Rav4
My Photos: (0)
Hey Red, in the above picture, are your blue cables power or speaker wires? What exactly is that white plastic thing called? Does that go on to feed your smaller power wires on the left?
Old 03-03-2005, 10:56 AM   #14
_
My Photos: (73)
those are speaker. We did that for two reasons actually, for the reason mentioned above, but also so that if I needed to put a speaker out of phase we could do so easily back there....then again, the alpine processor will switch phase as well...
it's basically a terminal strip
the other one that I listed (second pic) is actually a terminal strip. Basically, we brought power, ground and ignition to it, jumped them over to 3-4 other terminals and can split them from there, can also easily disconnect everything and trouble shoot, and test at this point as well
Jan Bennett
Old 03-03-2005, 11:11 AM   #15
VanMan69's Avatar
Vehicle: 1995 Chevy G20 Van
My Photos: (0)
Semi-ghetto 8-to-12ga:
Crimp ring terminals onto the 8ga and the 12ga's, then use a small nut/bolt/washer to bolt all the rings together securely, and wrap the whole thing in tape or heatshrink.
95 Chevy G20 Vroom Boom Room
...with a whole bunch of nifty ****... go check it out: VanDomain Page
VanMan69 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
What gauge wire for opus? XxAndyxX Power Supplies 6 01-19-2004 11:21 PM
Routing power button to front of PC. Can wire be too thick of gauge? LESLIEx317537 General Hardware Discussion 4 09-27-2003 02:32 PM
8 gauge wire BIG!? detz General Hardware Discussion 7 07-11-2002 02:23 PM
Attn: 15' foot 80 wire IDE works. Paid 16 buks. -DVD-ROM (Say Yes!) LESLIEx317537 General Hardware Discussion 30 02-14-2002 04:05 PM
how do I wire 16 x 2 LCD? maromba General Hardware Discussion 0 04-07-2000 09:01 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
