Notices
Old 03-12-2005, 07:28 PM   #1
Dim lights on display
My roommates antenna wire came loose and stopped pulling in radio stations. So we took out the radio and re attached the antenna cable. Now the front panel display is very very dim, but it was not dim before we took out the radio. Any suggestions on what the problem could be?
we pulled it back out and all the connections seem good between the wires.
drewinstl is offline   Reply With Quote
Old 03-12-2005, 09:39 PM   #2
HostileJava's Avatar
Most radio's have a dimmer line that run to them, when you turn on the headlights it dims the radio because it assumes it's dark out and doesn't need to be illuminated as much. Identify that wire and make sure it's not loose.
Visit my website at:
http://www.hostilejava.com
http://hostilejava.com/gerbil5.jpg
HostileJava is offline   Reply With Quote
Old 03-12-2005, 09:43 PM   #3
Self proclaimed spoon feeder
TruckinMP3's Avatar
also disconnecting power returns most to factory defaults... you may have a manual dimmer setting (my HU does)
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 03-13-2005, 08:47 AM   #4
_
some headunits will also be tied into the dimming option for your dash board....
I know on my car and on the truck you can dim the dash board lights and sometimes it will dim the radio as well...
might want to check that as well
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
D3 in C# application jadz Map Monkey 4 11-18-2004 10:29 AM
Telematics.net IntellaWorks Software & Software Development 40 11-05-2004 09:20 PM
Will having a larger screen size make up for a dim display ?? Cruznlife1 LCD/Display 4 10-04-2004 02:00 AM
Any way to relocate my display card?? SlimJimmy General Hardware Discussion 13 03-22-2004 10:14 PM
Choosing a Character display... Kryten LCD/Display 3 10-16-2003 11:43 PM
