Old 04-05-2005, 12:53 PM   #1
titaniumkingpin is on a distinguished road
Sound Skipping!! Please help
setup is a VIA M10000 w/ 512 DDR ram, 80 gig HDD, onboard soundcard, onboard video card.
Problem is....after downloading about 100 music videos i noticed about half woudn't play correctly (audio fine / no video). Some of the files play with no issues at all but some files need a codec.
so i installed PowerDVD and now they all play. Problem is the video plays but the audio is very choppy.
This also happens when playing DVD Audio media. When playing the music with only audio... no problem. When playing the audio with the video, audio skips.
What can the problem be? Seems like the bigger the file, the more likely it will skip.
titaniumkingpin is offline   Reply With Quote
Old 04-05-2005, 12:58 PM   #2
Thanks in advance to anyone who can troubleshoot this.
Old 04-05-2005, 02:24 PM   #3
Top Ramen
lgbr's Avatar
lgbr has a little shameless behaviour in the past
Many music videos are encoded in m2v format. This is also used for DVD's. The best decoder I've used is from elecard. Try that one. Also try WinDVD.
Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
Head units are for cheaters!
Quote:
sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
lgbr is offline   Reply With Quote
Old 04-05-2005, 02:45 PM   #4
But, i used powerdvd on other computers and all the music videos played fine.
Old 04-05-2005, 05:09 PM   #5
thanks, ill try elecard
Old 04-11-2005, 10:54 PM   #6
coconut924's Avatar
coconut924
I have the same problem with MP3's... Good ones, not rips. Downloads from itunes will skip even though they played perfect before. I also have an epia mII with onboard sound/video.
1997/Honda/Civic HB
coconut924 is offline   Reply With Quote
Old 04-12-2005, 03:34 AM   #7
sansoo24 is on a distinguished road
here is a little hint: ITS THE DAMNED 1GHZ CPU. Whens the last time you saw a decent computer use a 1ghz. IS the cpu getting really hot? Are you running a trimmed down vresion of Xp or Xp lite? Are unecessary processes running?
There is a whole ton of things you could look at.
sansoo24 is offline   Reply With Quote
Old 04-12-2005, 05:01 AM   #8
dave2 is on a distinguished road
The onboard video and audio are definately causing the problem. They just can't handle that kind of decoding. Try using an offboard sound card, usb or pci. That should isolate the processing enough to make your system struggle through it less
Dave
dave2 is offline   Reply With Quote
Old 04-12-2005, 07:13 PM   #9
UPDATE:
i updated my audio drivers from VIAs site and now things are better but not fixed.
Before on some files where video and audio would skip, now the audio is fine but the video still skips.
i should probably try a offboard video card.
Old 04-12-2005, 07:21 PM   #10
coconut924's Avatar
coconut924
CPU IS NOT HOT. RUNNING WIN2K. I HAVENT MODIFIED THE OS AT ALL. THE CPU IS RUNNING AT 15-20% AT MOST WITH iTUNES OR WINAMP. IT SEEMS LIKE THE SKIPPING IS GETTING PROGRESSIVLY WORSE.
I AM DEFRAGING THE HD TO SEE IF THAT WILL TAKE CARE OF THE PROBLEM. MOST OF MY SONGS ARE CD QUALITY WAV FILES BUT MP3'S SKIP TOO. AND THE DRIVE WAS FRAGGED REALLY BAD.
AND IT NEVER DID THIS UNTIL I PUT THE COMPUTER IN THE CAR.
1997/Honda/Civic HB
Old 04-12-2005, 09:18 PM   #11
coconut: The defrag is a good start. How much RAM do you have? Are you running amps for your speakers? Do you have a HU still? Is the system FM modulated if not amped? If the skipping isnt from the PC then its from something outside the system. IF the defrag doesnt work and it worked fine before it was in your car then the problem is more than likely electrical related and taking place outside the PC
Weird sound skipping in winamp (VIA EPIA 800) bayere General Hardware Discussion 5 09-08-2004 08:35 AM
Sound cards from incarpcs , sacrificing sound quality? skinhead General Hardware Discussion 15 09-02-2004 03:05 AM
Best possible sound quality ST43LTH General Hardware Discussion 17 07-06-2004 09:10 AM
Wanted: Clean sound from carpc slushieken Car Audio 8 06-20-2004 10:17 AM
got sound? masch Newbie 20 11-17-2003 10:01 AM
