Old 04-06-2005, 01:59 PM   #1
Scorpnstail is on a distinguished road
Question regarding FM modulators
I know there has been alot of disscussion in the past about these but I wanted to ask a quick question
I have heard FM modulators are not that good due to the fact that you will still get dominant radio waves trying to cut into your music.
However a friend of mine says that FM modulators that have a antenna hookup will make it so that when you are playing your music the antenna will be cut off and no more FM waves will be present to interfere with your signal.
Can anyone validate this or back this up as my knowledge of car audio is pretty nill.
Scorpnstail is offline   Reply With Quote
Old 04-06-2005, 02:41 PM   #2
mox
mox's Avatar
mox is on a distinguished road
The inline FM modulator that I've bought just recently contains a relay which indeed cuts the link from the car antenna to the HU as soon as 12V power is applied. I haven't tried it yet, so I have no idea about the overall sound quality. If it turns out to be really bad, I think I will sacrifice my cd changer and get an AUX-adapter from www.connects2.com.
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
mox is offline   Reply With Quote
Old 04-06-2005, 02:47 PM   #3
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
My personal experience, wireless ones are pointless. Around here anyway (Boston). Every one I've tried had a strong signal on all of the available channels. I ended up with a inline Kenwood one that works perfectly. I don't believe they make it anymore though.
shotgunefx is offline   Reply With Quote
Old 04-06-2005, 03:09 PM   #4
cd25987 is on a distinguished road
Even the inline modulators let stonger interferance in. FM Modulators are not the way to go if you want good quality input. I learned the hard way....
cd25987 is offline   Reply With Quote
Old 04-06-2005, 03:11 PM   #5
Raw Wave
shotgunefx's Avatar
For me, so far so good. Though outside of replacing my HU or amp, it was my only option I could get working. I'm happy with my setup so I didn't want to replace it just to use my nomad.
Old 04-06-2005, 03:13 PM   #6
Yea .. that is what I am refering to ( Inline modulators )
How would it be possilbe for something to get though if you basicly block the FM signal from ant. ?
Old 04-06-2005, 03:28 PM   #7
joelw23 is on a distinguished road
I have one for sale if anyone is interested...pm me...
joelw23 is offline   Reply With Quote
Old 04-06-2005, 03:59 PM   #8
mox
mox's Avatar
The modulator sits inbetween the outside aerial and the HU. Once power is applied, the aerial gets disconnected from the modulator so radio stations cannot interfere with the signal coming from the modulator (hopefully...).
Think of the modulator as a normal FM radio station with its own fixed frequency.
Software: RR, MM/FD
Old 04-06-2005, 04:07 PM   #9
thanks for explaining that .. I did understand how it worked but I was curious on if the aerial is disconnected how can any other signal other then the one from the FM modulator get through.
Old 04-06-2005, 04:16 PM   #10
mox
mox's Avatar
It can't You are supposed to turn the modulator off if you want to listen to normal radio stations. It stops "transmitting" and the relay restores connection between antenna and HU.
Software: RR, MM/FD
Old 04-06-2005, 04:21 PM   #11
Raw Wave
shotgunefx's Avatar
Mine doesn't have a switch to turn it off.
Old 04-06-2005, 04:31 PM   #12
dave2 is on a distinguished road
Does it have a power wire? Sometimes you just gotta do things yourself...
dave2 is offline   Reply With Quote
Old 04-06-2005, 04:37 PM   #13
Raw Wave
shotgunefx's Avatar
Yeah, it does, but I've never needed to shut it off. It doesn't interfere with my radio (outside of loosing one channel I would never listen to) and when I have something plugged into it, the antenna doesn't interfere with it so no reason to.
TV FM Tuner Driver Question doctorr General Hardware Discussion 2 08-02-2005 02:16 AM
FM Modulator Question frenchbluefocus Newbie 2 11-24-2004 12:05 PM
Very cool FM transmitter and easy wiring question wompser General Hardware Discussion 18 04-24-2004 05:11 PM
Consenus on quality Power Inverters and FM Modulators dodgetimes2 General Hardware Discussion 14 04-14-2004 09:21 AM
{Aus} FM Modulators eminence General Hardware Discussion 18 11-02-2003 11:20 PM
