Quote: Originally Posted by 93blacksrv
Aren't car speakers 4 ohm while home speakers are 8 ohm and if so, what effect will this have on car speakers given the fact that the computer outputs 8??
well you run your computer output into an amp and then into the speakers, you cant run them straight into the speakers, and car amps are generally made for 4 ohms
and as a general rule its easier to build more precise speakers at higher impedences, the reason why car speakers are lower impedence than home speakers is that higher impedence speakers require more voltage to drive. Its hard to get high voltages in a car environment when the source is 12v
